AirPressureSensor Class Reference
#include <AirPressureSensor.hh>
| AirPressureSensor () | |
| constructor More... | |
| virtual | ~AirPressureSensor () |
| destructor More... | |
| double | ReferenceAltitude () const |
| Get the vertical reference altitude. More... | |
| void | SetReferenceAltitude (double _reference) |
| Set the reference altitude. More... | |
| virtual bool | Update (const common::Time &_now) override |
| virtual | ~Sensor () |
| Add a sequence number to an gz::msgs::Header. This function can be called by a sensor that wants to add a sequence number to a sensor message in order to have improved accountability for generated sensor data. More... | |
| FrameId. More... | |
| SensorId | Id () const |
| Get name. More... | |
| common::Time | NextUpdateTime () const |
| bool | Update (const common::Time &_now, const bool _force) |
| Sensor () | |
A sensor that reports air pressure readings.
◆ AirPressureSensor()
constructor
◆ ~AirPressureSensor()
virtual |
destructor
◆ Init()
overridevirtual |
◆ Load() [1/2]
overridevirtual |
◆ Load() [2/2]
overridevirtual |
◆ ReferenceAltitude()
| double ReferenceAltitude | ( | ) | const |
- Returns
- Verical reference position in meters
◆ SetReferenceAltitude()
| void SetReferenceAltitude | ( | double | _reference | ) |
[in] _ref Verical reference position in meters
◆ Update()
overridevirtual |
[in] _now The current time
- Returns
Implements Sensor.
