Gazebo Sensors
ThermalCameraSensor Class Reference
#include <ThermalCameraSensor.hh>
 ThermalCameraSensor ()
 constructor More...
virtual ~ThermalCameraSensor ()
 destructor More...
common::ConnectionPtr ConnectImageCallback (std::function< void(const msgs::Image &)> _callback)
 Get image height. More...
 Get image width. More...
virtual bool Init () override
void OnNewThermalFrame (const uint16_t *_scan, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)
 Thermal data callback used to get the data from the sensor. More...
virtual void SetAmbientTemperature (float _ambient)
 Set the ambient temperature of the environment. More...
virtual void SetAmbientTemperatureRange (float _range)
 Set the range of ambient temperature. More...
virtual void SetLinearResolution (float _resolution)
 Set the temperature linear resolution. The thermal image data returned will be temperature in kelvin / resolution. Typical values are 0.01 (10mK), 0.1 (100mK), or 0.04 to simulate 14 bit format. More...
virtual void SetMaxTemperature (float _max)
 Set the maximum temperature the sensor can detect. More...
virtual void SetMinTemperature (float _min)
 Set the minimum temperature the sensor can detect. More...
virtual rendering::ThermalCameraPtr ThermalCamera ()
virtual bool Update (const common::Time &_now) override
 CameraSensor ()
 constructor More...
virtual ~CameraSensor ()
 destructor More...
double Baseline () const
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
std::string Name () const
 Get name. More...
common::Time NextUpdateTime () const
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
std::string Topic () const
bool Update (const common::Time &_now, const bool _force)
 Update the sensor. More...
double UpdateRate () const
bool AdvertiseInfo ()
void PublishInfo (const gz::common::Time &_now)
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
This class creates thermal image from an ignition rendering scene. The scene must be created in advance and given to Manager::Init(). It offers both an ignition-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ ThermalCameraSensor()
constructor
◆ ~ThermalCameraSensor()
virtual ~ThermalCameraSensor ( )
destructor
◆ ConnectImageCallback()
common::ConnectionPtr ConnectImageCallback ( std::function< void(const msgs::Image &)>  _callback)
Remarks
◆ ImageHeight()
Get image height.
height of the image
◆ ImageWidth()
Get image width.
width of the image
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ OnNewThermalFrame()
void OnNewThermalFrame ( const uint16_t *  _scan,
const std::string &  _format
[in]_scanpointer to the data from the sensor
[in]_widthwidth of the thermal image
[in]_heightheight of the thermal image
[in]_channelbytes used for the thermal data
[in]_formatstring with the format
◆ SetAmbientTemperature()
virtual void SetAmbientTemperature ( float  _ambient)
[in]_ambientAmbient temperature in kelvin
◆ SetAmbientTemperatureRange()
virtual void SetAmbientTemperatureRange ( float  _range)
[in]_rangeThe ambient temperature ranges from (ambient - range/2) to (ambient + range/2).
◆ SetLinearResolution()
virtual void SetLinearResolution ( float  _resolution)
[in]resolutionTemperature linear resolution
◆ SetMaxTemperature()
virtual void SetMaxTemperature ( float  _max)
[in]_maxMax temperature in kelvin
◆ SetMinTemperature()
virtual void SetMinTemperature ( float  _min)
[in]_minMin temperature in kelvin
◆ SetScene()
◆ ThermalCamera()
virtual rendering::ThermalCameraPtr ThermalCamera ( )
[in]_nowThe current time
virtual bool Update ( const common::Time &  _now)
