RgbdCameraSensor Class Reference
#include <RgbdCameraSensor.hh>
| RgbdCameraSensor () | |
| constructor More... | |
| virtual | ~RgbdCameraSensor () |
| destructor More... | |
| Get image height. More... | |
| Get image width. More... | |
| virtual void | SetScene (gz::rendering::ScenePtr _scene) override |
| Set the rendering scene. More... | |
| virtual bool | Update (const common::Time &_now) override |
Public Member Functions inherited from CameraSensor | |
| CameraSensor () | |
| virtual | ~CameraSensor () |
| double | Baseline () const |
| Get baseline for stereo cameras. More... | |
| gz::common::ConnectionPtr | ConnectImageCallback (std::function< void(const gz::msgs::Image &)> _callback) |
| Set a callback to be called when image frame data is generated. More... | |
| std::string | InfoTopic () const |
| Topic where camera info is published. More... | |
| rendering::CameraPtr | RenderingCamera () const |
| Get pointer to rendering camera object. More... | |
| void | SetBaseline (double _baseline) |
| Set baseline for stereo cameras. This is used to populate the projection matrix in the camera info message. More... | |
Public Member Functions inherited from RenderingSensor | |
| virtual | ~RenderingSensor () |
| bool | ManualSceneUpdate () const |
| Get whether the scene graph is updated manually. Defaults to false. More... | |
| void | Render () |
| Render update. This performs the actual render operation. More... | |
| rendering::ScenePtr | Scene () const |
| Get the rendering scene. More... | |
| void | SetManualSceneUpdate (bool _manual) |
| Set whether to update the scene graph manually. If set to true, it is expected that rendering::Scene::PreRender is called manually before calling Render() More... | |
| virtual void | SetScene (rendering::ScenePtr _scene) |
| virtual | ~Sensor () |
| Add a sequence number to an gz::msgs::Header. This function can be called by a sensor that wants to add a sequence number to a sensor message in order to have improved accountability for generated sensor data. More... | |
| FrameId. More... | |
| SensorId | Id () const |
| Get name. More... | |
| common::Time | NextUpdateTime () const |
| bool | Update (const common::Time &_now, const bool _force) |
Protected Member Functions inherited from CameraSensor | |
| bool | AdvertiseInfo () |
| Advertise camera info topic. More... | |
| bool | AdvertiseInfo (const std::string &_topic) |
| Advertise camera info topic. This version takes a string that allows one to override the camera_info topic. More... | |
| void | PopulateInfo (const sdf::Camera *_cameraSdf) |
| Populate camera info message. More... | |
| void | PublishInfo (const gz::common::Time &_now) |
| Publish camera info message. More... | |
Protected Member Functions inherited from RenderingSensor | |
| RenderingSensor () | |
| void | AddSensor (rendering::SensorPtr _sensor) |
| Add a rendering::Sensor. Its render updates will be handled by this base class. More... | |
| Sensor () | |
This class creates a few types of sensor data from an ignition rendering scene:
- RGB image (same as CameraSensor)
- Depth image (same as DepthCamera)
- (future / todo) Color point cloud The scene must be created in advance and given to Manager::Init(). It offers both an ignition-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ RgbdCameraSensor()
| RgbdCameraSensor | ( | ) |
constructor
◆ ~RgbdCameraSensor()
virtual |
destructor
◆ ImageHeight()
overridevirtual |
◆ ImageWidth()
overridevirtual |
◆ Init()
overridevirtual |
◆ Load()
overridevirtual |
[in] _sdf SDF Sensor parameters.
- Returns
- true if loading was successful
◆ SetScene()
overridevirtual |
◆ Update()
overridevirtual |
[in] _now The current time
- Returns
- true if the update was successful
