| | LogicalCameraSensor () |
| | constructor More...
| virtual | ~LogicalCameraSensor () |
| | destructor More...
| double | AspectRatio () const |
| | Get the aspect ratio, which is the width divided by height of the near or far planes. More...
| double | Far () const |
| | Get the far distance. This is the distance from the frustum's vertex to the farthest plane. More...
| gz::math::Angle | HorizontalFOV () const |
| | Get the horizontal field of view. The field of view is the angle between the frustum's vertex and the edges of the near or far plane. This value represents the horizontal angle. More...
| msgs::LogicalCameraImage | Image () const |
| | Get the latest image. An image is an instance of msgs::LogicalCameraImage, which contains a list of detected models. More...
| | Initialize values in the sensor. More...
| | Load the sensor with SDF parameters. More...
| double | Near () const |
| | Get the near distance. This is the distance from the frustum's vertex to the closest plane. More...
| void | SetModelPoses (std::map< std::string, math::Pose3d > &&_models) |
| | Set the models currently in the world. More...
| virtual bool | Update (const common::Time &_now) override |
| | Force the sensor to generate data. More...
| virtual | ~Sensor () |
| | destructor More...
| | Add a sequence number to an gz::msgs::Header. This function can be called by a sensor that wants to add a sequence number to a sensor message in order to have improved accountability for generated sensor data. More...
| | Get flag state for enabling performance metrics publication. More...
| | FrameId. More...
| SensorId | Id () const |
| | Get the sensor's ID. More...
| virtual bool | Load (const sdf::Sensor &_sdf) |
| | Load the sensor based on data from an sdf::Sensor object. More...
| | Get name. More...
| common::Time | NextUpdateTime () const |
| | Return the next time the sensor will generate data. More...
| | Get parent link of the sensor. More...
| | Get the current pose. More...
| | Publishes information about the performance of the sensor. This method is called by Update(). More...
| | Get the SDF used to load this sensor. More...
| | Set flag to enable publishing performance metrics. More...
| | Set Frame ID of the sensor. More...
| | Set the parent of the sensor. More...
| | Update the pose of the sensor. More...
| | Set topic where sensor data is published. More...
| | Set the update rate of the sensor. An update rate of zero means that the sensor is updated every cycle. It's zero by default. \detail Negative rates become zero. More...
| | Get topic where sensor data is published. More...
| bool | Update (const common::Time &_now, const bool _force) |
| | Update the sensor. More...
| | Get the update rate of the sensor. More...
Logical Camera Sensor Class.
A logical camera reports locations of objects. This camera finds models within the sensor's frustum and publishes information about the models on the sensor's topic.
