AltimeterSensor Class Reference
#include <AltimeterSensor.hh>
| AltimeterSensor () | |
| constructor More... | |
| virtual | ~AltimeterSensor () |
| destructor More... | |
| void | SetPosition (double _pos) |
| Set the current z position of the altimeter. More... | |
| void | SetVerticalReference (double _reference) |
| Set the vertical reference position of the altimeter. More... | |
| void | SetVerticalVelocity (double _vel) |
| Set the vertical velocity of the altimeter. More... | |
| virtual bool | Update (const common::Time &_now) override |
| double | VerticalPosition () const |
| Get the vertical position of the altimeter relative to the reference position. More... | |
| double | VerticalReference () const |
| Get the vertical reference position of the altimeter. More... | |
| double | VerticalVelocity () const |
| Get the vertical velocity of the altimeter. More... | |
| virtual | ~Sensor () |
| Add a sequence number to an gz::msgs::Header. This function can be called by a sensor that wants to add a sequence number to a sensor message in order to have improved accountability for generated sensor data. More... | |
| FrameId. More... | |
| SensorId | Id () const |
| Get name. More... | |
| common::Time | NextUpdateTime () const |
| bool | Update (const common::Time &_now, const bool _force) |
| Sensor () | |
An altimeter sensor that reports vertical position and velocity readings over ign transport
◆ AltimeterSensor()
| AltimeterSensor | ( | ) |
constructor
◆ ~AltimeterSensor()
virtual |
destructor
◆ Init()
overridevirtual |
◆ Load() [1/2]
overridevirtual |
◆ Load() [2/2]
overridevirtual |
◆ SetPosition()
| void SetPosition | ( | double | _pos | ) |
[in] _pos Z position in meters
◆ SetVerticalReference()
| void SetVerticalReference | ( | double | _reference | ) |
[in] _ref Verical reference position in meters
◆ SetVerticalVelocity()
| void SetVerticalVelocity | ( | double | _vel | ) |
[in] _vel Vertical velocity in meters per second
◆ Update()
overridevirtual |
[in] _now The current time
- Returns
Implements Sensor.
◆ VerticalPosition()
| double VerticalPosition | ( | ) | const |
- Returns
- Vertical position relative to referene position
◆ VerticalReference()
| double VerticalReference | ( | ) | const |
- Returns
- Verical reference position in meters
◆ VerticalVelocity()
| double VerticalVelocity | ( | ) | const |
- Returns
- Vertical velocity in meters per second
