Gazebo Sensors
Lidar Sensor Class. More...
#include <Lidar.hh>
 Lidar ()
 constructor More...
virtual ~Lidar ()
 destructor More...
gz::math::Angle AngleMax () const
 Get the maximum angle. More...
gz::math::Angle AngleMin () const
 Get the minimum angle. More...
double AngleResolution () const
 Get radians between each range. More...
void ApplyNoise ()
 Apply noise to the laser buffer, if noise has been configured. This should be called before PublishLidarScan if you want the scan data to contain noise. More...
virtual gz::common::ConnectionPtr ConnectNewLidarFrame (std::function< void(const float *_scan, unsigned int _width, unsigned int _heighti, unsigned int _channels, const std::string &)> _subscriber)
 Set a callback to be called when data is generated. More...
virtual bool CreateLidar ()
 Create Lidar sensor. More...
int Fiducial (const unsigned int _index) const
 Get detected fiducial value for a ray. Warning: If you are accessing all the ray data in a loop it's possible that the Ray will update in the middle of your access loop. This means some data will come from one scan, and some from another scan. You can solve this problem by using SetActive(false) <your accessor loop> SetActive(true). More...
double HorzFOV () const
 Get the horizontal field of view of the laser sensor. More...
virtual bool Init () override
virtual bool IsActive () const
bool IsHorizontal () const
virtual bool PublishLidarScan (const common::Time &_now)
 Publish LaserScan message. More...
double Range (const int _index) const
 Get detected range for a ray. Warning: If you are accessing all the ray data in a loop it's possible that the Ray will update in the middle of your access loop. This means some data will come from one scan, and some from another scan. You can solve this problem by using SetActive(false) <your accessor loop> SetActive(true). More...
unsigned int RangeCount () const
 Get the range count. More...
double RangeCountRatio () const
 Return the ratio of horizontal range count to vertical range count. More...
double RangeMax () const
 Get the maximum range. More...
double RangeMin () const
 Get the minimum range. More...
double RangeResolution () const
 Get the range resolution If RangeResolution is 1, the number of simulated rays is equal to the number of returned range readings. If it's less than 1, fewer simulated rays than actual returned range readings are used, the results are interpolated from two nearest neighbors, and vice versa. More...
void Ranges (std::vector< double > &_ranges) const
 Get all the ranges. More...
unsigned int RayCount () const
 Get the ray count. More...
double RayCountRatio () const
 Return the ratio of horizontal ray count to vertical ray count. More...
double Retro (const int _index) const
 Get detected retro (intensity) value for a ray. Warning: If you are accessing all the ray data in a loop it's possible that the Ray will update in the middle of your access loop. This means some data will come from one scan, and some from another scan. You can solve this problem by using SetActive(false) <your accessor loop> SetActive(true). More...
void SetAngleMax (const double _angle)
 Set the scan maximum angle. More...
void SetAngleMin (const double _angle)
 Set the scan minimum angle. More...
void SetParent (const std::string &_parent) override
void SetVerticalAngleMax (const double _angle)
 Set the vertical scan line top angle. More...
void SetVerticalAngleMin (const double _angle)
 Set the vertical scan bottom angle. More...
virtual bool Update (const common::Time &_now) override
double VertFOV () const
gz::math::Angle VerticalAngleMax () const
 Get the vertical scan line top angle. More...
gz::math::Angle VerticalAngleMin () const
 Get the vertical scan bottom angle. More...
double VerticalAngleResolution () const
 Get the vertical angle in radians between each range. More...
unsigned int VerticalRangeCount () const
 Get the vertical scan line count. More...
unsigned int VerticalRayCount () const
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
std::string Name () const
 Get name. More...
common::Time NextUpdateTime () const
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
std::string Topic () const
bool Update (const common::Time &_now, const bool _force)
 Update the sensor. More...
double UpdateRate () const
Public Attributes
bool initialized = false
 true if Load() has been called and was successful More...
float * laserBuffer = nullptr
 Raw buffer of laser data. More...
std::mutex lidarMutex
 Just a mutex for thread safety. More...
virtual void Fini ()
 Finalize the ray. More...
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
Lidar Sensor Class.
This class creates laser scans using. It's measures the range from the origin of the center to points on the visual geometry in the scene.
It offers both an ignition-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ Lidar()
Lidar ( )
constructor
◆ ~Lidar()
virtual ~Lidar ( )
destructor
◆ AngleMax()
gz::math::Angle AngleMax ( ) const
the maximum angle
◆ AngleMin()
gz::math::Angle AngleMin ( ) const
The minimum angle
◆ AngleResolution()
double AngleResolution ( ) const
Return angle resolution
◆ ApplyNoise()
void ApplyNoise ( )
◆ ConnectNewLidarFrame()
virtual gz::common::ConnectionPtr ConnectNewLidarFrame ( std::function< void(const float *_scan, unsigned int _width, unsigned int _heighti, unsigned int _channels, const std::string &)>  _subscriber)
[in]_callbackThis callback will be called every time the sensor generates data. The Update function will be blocked while the callbacks are executed.
Remarks
Reimplemented in GpuLidarSensor.
◆ CreateLidar()
virtual bool CreateLidar ( )
◆ Fiducial()
int Fiducial ( const unsigned int  _index) const
[in]_indexIndex of specific ray
Fiducial value of ray
◆ Fini()
virtual void Fini ( )
Finalize the ray.
◆ HorzFOV()
double HorzFOV ( ) const
The horizontal field of view of the laser sensor.
virtual bool Init ( )
True on success
Reimplemented from Sensor.
◆ IsActive()
virtual bool IsActive ( ) const
◆ IsHorizontal()
bool IsHorizontal ( ) const
◆ Load() [1/2]
◆ Load() [2/2]
◆ PublishLidarScan()
virtual bool PublishLidarScan ( const common::Time &  _now)
[in]_nowThe current time
◆ Range()
double Range ( const int  _index) const
Returns RangeMax for no detection.
◆ RangeCount()
unsigned int RangeCount ( ) const
The number of ranges
◆ RangeCountRatio()
double RangeCountRatio ( ) const
A ray count is the number of simulated rays. Whereas a range count is the total number of data points returned. When range count != ray count, then values are interpolated between rays.
◆ RangeMax()
double RangeMax ( ) const
The maximum range
◆ RangeMin()
double RangeMin ( ) const
The minimum range
◆ RangeResolution()
double RangeResolution ( ) const
The Range Resolution
◆ Ranges()
void Ranges ( std::vector< double > &  _ranges) const
Get all the ranges.
[out]_rangeA vector that will contain all the range data
◆ RayCount()
unsigned int RayCount ( ) const
Get the ray count.
The number of rays
◆ RayCountRatio()
double RayCountRatio ( ) const
◆ Retro()
double Retro ( const int  _index) const
Intensity value of ray
◆ SetAngleMax()
void SetAngleMax ( const double  _angle)
[in]_angleThe maximum angle
◆ SetAngleMin()
void SetAngleMin ( const double  _angle)
[in]_angleThe minimum angle
◆ SetParent()
void SetParent ( const std::string &  _parent)
True on success
◆ SetVerticalAngleMax()
void SetVerticalAngleMax ( const double  _angle)
[in]_angleThe Maximum angle of the scan block
◆ SetVerticalAngleMin()
void SetVerticalAngleMin ( const double  _angle)
[in]_angleThe minimum angle of the scan block
virtual bool Update ( const common::Time &  _now)
Implements Sensor.
◆ VertFOV()
double VertFOV ( ) const
Vertical field of view.
◆ VerticalAngleMax()
gz::math::Angle VerticalAngleMax ( ) const
◆ VerticalAngleMin()
gz::math::Angle VerticalAngleMin ( ) const
◆ VerticalAngleResolution()
double VerticalAngleResolution ( ) const
Resolution of the angle
◆ VerticalRangeCount()
unsigned int VerticalRangeCount ( ) const
The number of scan lines vertically
◆ VerticalRayCount()
unsigned int VerticalRayCount ( ) const
◆ initialized
◆ laserBuffer
float* laserBuffer = nullptr
◆ lidarMutex
mutable
