Gazebo Sensors
gz/sensors/Lidar.hh
16 */
17 #ifndef GZ_SENSORS_LIDAR_HH_
18 #define GZ_SENSORS_LIDAR_HH_
20 #include <memory>
21 #include <string>
22 #include <vector>
23
24 #include <gz/common/SuppressWarning.hh>
25 #include <gz/common/Event.hh>
26
27 #include "gz/sensors/lidar/Export.hh"
29
30 namespace ignition
31 {
32  namespace sensors
33  {
34  // Inline bracket to help doxygen filtering.
35  inline namespace IGNITION_SENSORS_VERSION_NAMESPACE {
36  //
38  class LidarPrivate;
39
49  class IGNITION_SENSORS_LIDAR_VISIBLE Lidar : public RenderingSensor
50  {
52  public: Lidar();
53
55  public: virtual ~Lidar();
56
60  public: virtual bool Update(
61  const std::chrono::steady_clock::duration &_now) override;
62
66  public: void ApplyNoise();
67
71  public: virtual bool PublishLidarScan(
72  const std::chrono::steady_clock::duration &_now);
73
77  public: virtual bool Load(const sdf::Sensor &_sdf) override;
78
82  public: virtual bool Load(sdf::ElementPtr _sdf) override;
83
86  public: virtual bool Init() override;
87
90  public: void SetParent(const std::string &_parent) override;
91
93  public: virtual bool CreateLidar();
94
96  protected: virtual void Fini();
97
100  public: gz::math::Angle AngleMin() const;
101
104  public: void SetAngleMin(const double _angle);
105
108  public: gz::math::Angle AngleMax() const;
109
112  public: void SetAngleMax(const double _angle);
113
116  public: double AngleResolution() const;
117
120  public: double RangeMin() const;
121
124  public: double RangeMax() const;
125
133  public: double RangeResolution() const;
134
137  public: unsigned int RayCount() const;
138
141  public: unsigned int RangeCount() const;
142
145  public: unsigned int VerticalRayCount() const;
146
149  public: unsigned int VerticalRangeCount() const;
150
153  public: gz::math::Angle VerticalAngleMin() const;
154
157  public: void SetVerticalAngleMin(const double _angle);
158
161  public: gz::math::Angle VerticalAngleMax() const;
162
165  public: void SetVerticalAngleMax(const double _angle);
166
169  public: double VerticalAngleResolution() const;
170
180  public: double Range(const int _index) const;
181
184  public: void Ranges(std::vector<double> &_ranges) const;
185
195  public: double Retro(const int _index) const;
196
206  public: int Fiducial(const unsigned int _index) const;
207
210  public: bool IsHorizontal() const;
211
218  public: double RayCountRatio() const;
219
226  public: double RangeCountRatio() const;
227
230  public: double HorzFOV() const;
231
234  public: double VertFOV() const;
235
236  // Documentation inherited
237  public: virtual bool IsActive() const;
238
242  public: bool HasConnections() const;
243
246  public: uint32_t VisibilityMask() const;
247
253  private: double Clamp(double _range) const;
254
255  IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING
257  public: mutable std::mutex lidarMutex;
258  IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING
259
261  public: float *laserBuffer = nullptr;
262
264  public: bool initialized = false;
265
273  public: virtual gz::common::ConnectionPtr ConnectNewLidarFrame(
274  std::function<void(const float *_scan, unsigned int _width,
275  unsigned int _heighti, unsigned int _channels,
276  const std::string &/*_format*/)> _subscriber);
277
278  IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING
281  private: std::unique_ptr<LidarPrivate> dataPtr;
282  IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING
283  };
284  }
285  }
286 }
287
288 #endif
Lidar Sensor Class.
Definition: gz/sensors/Lidar.hh:50
Get detected range for a ray. Warning: If you are accessing all the ray data in a loop it's possible ...
Get the horizontal field of view of the laser sensor.
Get the maximum range.
Get the vertical angle in radians between each range.
Get the vertical scan line top angle.
Set the scan maximum angle.
virtual void Fini()
Finalize the ray.
Get the vertical scan line count.
Return the ratio of horizontal range count to vertical range count.
Get the maximum angle.
Get the minimum range.
Get the vertical scan bottom angle.
Set the vertical scan line top angle.
virtual ~Lidar()
destructor
Get the range resolution If RangeResolution is 1, the number of simulated rays is equal to the number...
virtual bool PublishLidarScan(const std::chrono::steady_clock::duration &_now)
Publish LaserScan message.
void ApplyNoise()
Apply noise to the laser buffer, if noise has been configured. This should be called before PublishLi...
Get the range count.
Return the ratio of horizontal ray count to vertical ray count.
void Ranges(std::vector< double > &_ranges) const
Get all the ranges.
virtual gz::common::ConnectionPtr ConnectNewLidarFrame(std::function< void(const float *_scan, unsigned int _width, unsigned int _heighti, unsigned int _channels, const std::string &)> _subscriber)
Set a callback to be called when data is generated.
Get radians between each range.
virtual bool Update(const std::chrono::steady_clock::duration &_now) override
Create Lidar sensor.
Get detected retro (intensity) value for a ray. Warning: If you are accessing all the ray data in a l...
Set the scan minimum angle.
Get detected fiducial value for a ray. Warning: If you are accessing all the ray data in a loop it's ...
Set the vertical scan bottom angle.
Gets if sensor is horizontal.
Just a mutex for thread safety.
Definition: gz/sensors/Lidar.hh:257
Get the visibility mask.
Check if there are any subscribers for sensor data.
Get the ray count.
Get the minimum angle.
a rendering sensor class
Definition: gz/sensors/RenderingSensor.hh:54
