Gazebo Sensors
gz/sensors/SegmentationCameraSensor.hh
16 */
17
18 #ifndef IGNITION_SENSORS_SEGMENTATIONCAMERASENSOR_HH_
19 #define IGNITION_SENSORS_SEGMENTATIONCAMERASENSOR_HH_
20
21 #include <memory>
22 #include <string>
23
24 #include <ignition/common/Event.hh>
25 #include <ignition/common/PluginMacros.hh>
26 #include <ignition/common/SuppressWarning.hh>
27 #include <ignition/common/Time.hh>
28 #include <ignition/msgs.hh>
29 #include <ignition/transport/Node.hh>
30 #include <ignition/transport/Publisher.hh>
31 #include <sdf/sdf.hh>
32
36
38
39 namespace ignition
40 {
41  namespace sensors
42  {
43  // Inline bracket to help doxygen filtering.
44  inline namespace IGNITION_SENSORS_VERSION_NAMESPACE {
45  // forward declarations
46  class SegmentationCameraSensorPrivate;
47
55  class IGNITION_SENSORS_SEGMENTATION_CAMERA_VISIBLE
57  {
60
62  public: virtual ~SegmentationCameraSensor();
63
67  public: virtual bool Load(const sdf::Sensor &_sdf) override;
68
72  public: virtual bool Load(sdf::ElementPtr _sdf) override;
73
76  public: virtual bool Init() override;
77
81  public: virtual bool Update(
82  const std::chrono::steady_clock::duration &_now) override;
83
86  public: rendering::SegmentationCameraPtr SegmentationCamera() const;
87
94  public: void OnNewSegmentationFrame(const uint8_t * _data,
95  unsigned int _width, unsigned int _height, unsigned int _channels,
96  const std::string &_format);
97
106  public: ignition::common::ConnectionPtr ConnectImageCallback(
107  std::function<void(const ignition::msgs::Image &)> _callback);
108
111  public: virtual void SetScene(
112  ignition::rendering::ScenePtr _scene) override;
113
116  public: virtual unsigned int ImageWidth() const override;
117
120  public: virtual unsigned int ImageHeight() const override;
121
125  public: bool HasConnections() const;
126
129  private: bool CreateCamera();
130
131  IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING
135  IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING
136  };
137  }
138  }
139 }
140
141 #endif
Camera Sensor Class.
Definition: gz/sensors/CameraSensor.hh:72
Segmentation camera sensor class.
Definition: gz/sensors/SegmentationCameraSensor.hh:57
virtual void SetScene(ignition::rendering::ScenePtr _scene) override
Set the rendering scene.
void OnNewSegmentationFrame(const uint8_t *_data, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)
Segmentation data callback used to get the data from the sensor.
ignition::common::ConnectionPtr ConnectImageCallback(std::function< void(const ignition::msgs::Image &)> _callback)
Set a callback to be called when image frame data is generated.
Get image height.
virtual bool Update(const std::chrono::steady_clock::duration &_now) override
Get the rendering segmentation camera.
Get image width.
