gz/sim/components/JointAxis.hh
17 #ifndef GZ_GAZEBO_COMPONENTS_JOINTAXIS_HH_
18 #define GZ_GAZEBO_COMPONENTS_JOINTAXIS_HH_
20 #include <gz/msgs/axis.pb.h>
21 #include <sdf/JointAxis.hh>
26
27 namespace ignition
28 {
29 namespace gazebo
30 {
33 namespace serializers
34 {
35  using JointAxisSerializer =
37 }
38 namespace components
39 {
42  using JointAxis = Component<sdf::JointAxis, class JointAxisTag,
43  serializers::JointAxisSerializer>;
45  "ign_gazebo_components.JointAxis", JointAxis)
46
49  using JointAxis2 = Component<sdf::JointAxis, class JointAxis2Tag,
50  serializers::JointAxisSerializer>;
52  "ign_gazebo_components.JointAxis2", JointAxis2)
53 }
54 }
55 }
56 }
57
58 #endif
serializers::ComponentToMsgSerializer< sdf::JointAxis, msgs::Axis > JointAxisSerializer
Definition: gz/sim/components/JointAxis.hh:36
Definition: gz/sim/components/Serialization.hh:72
Component< sdf::JointAxis, class JointAxisTag, serializers::JointAxisSerializer > JointAxis
A component that contains the joint axis . This is a simple wrapper around sdf::JointAxis.
Definition: gz/sim/components/JointAxis.hh:43
