gz/sim/components/JointPositionLimitsCmd.hh File Reference
#include <vector>
#include <gz/math/Vector2.hh>
#include <gz/sim/config.hh>
#include <gz/sim/Export.hh>
Namespaces | |
ignition | |
This library is part of the Ignition Robotics project. | |
ignition::gazebo | |
ignition::gazebo::components | |
Components represent data, such as position information. An Entity usually has one or more associated components. | |
Typedefs | |
using | JointPositionLimitsCmd = Component< std::vector< gz::math::Vector2d >, class JointPositionLimitsCmdTag, serializers::VectorSerializer< gz::math::Vector2d > > |
Command for setting position limits of a joint. Data are a vector with a Vector2 for each DOF. The X() component of the Vector2 specifies the minimum positional limit, the Y() component stands for maximum limit. Set to +-infinity to disable the limits. More... | |
