include/gz/sim/components/DetachableJoint.hh File Reference
#include <string>
#include <gz/sim/Entity.hh>
#include <gz/sim/config.hh>
struct  DetachableJointInfo
 Data structure to hold information about the parent and child links connected by a detachable joint. More...
class  DetachableJointInfoSerializer
 Serializer for DetachableJointInfo object. More...
 ignition
 ignition::gazebo
 ignition::gazebo::components
 ignition::gazebo::serializers
using DetachableJoint = Component< DetachableJointInfo, class DetachableJointTag, serializers::DetachableJointInfoSerializer >
 A component that identifies an entity as being a detachable joint. It also contains additional information about the joint. More...
