src/systems/detachable_joint/DetachableJoint.hh
uint64_t Entity
Definition: gz/sim/Entity.hh:59
STL class.
Definition: gz/sim/EntityComponentManager.hh:65
This class provides wrappers around entities and components which are more convenient and straight-fo...
Definition: gz/sim/Model.hh:60
Component< DetachableJointInfo, class DetachableJointTag, serializers::DetachableJointInfoSerializer > DetachableJoint
A component that identifies an entity as being a detachable joint. It also contains additional inform...
Definition: include/gz/sim/components/DetachableJoint.hh:96
Definition: gz/sim/EventManager.hh:50
Definition: include/gz/sim/Types.hh:37
void PreUpdate(const gz::sim::UpdateInfo &_info, gz::sim::EntityComponentManager &_ecm) final
Documentation inherited.
transport::Node node
Ignition communication node.
Definition: src/systems/detachable_joint/DetachableJoint.hh:107
const Entity kNullEntity
Indicates a non-existant or invalid Entity.
Definition: gz/sim/Entity.hh:62
DetachableJoint()=default
Interface for a system that uses the PreUpdate phase.
Definition: gz/sim/System.hh:105
Interface for a system that implements optional configuration.
Definition: gz/sim/System.hh:88
A system that initially attaches two models via a fixed joint and allows for the models to get detach...
Definition: src/systems/detachable_joint/DetachableJoint.hh:57
void Configure(const Entity &_entity, const std::shared_ptr< const sdf::Element > &_sdf, EntityComponentManager &_ecm, EventManager &_eventMgr) final
