This class provides wrappers around entities and components which are more convenient and straight-forward to use than dealing with the EntityComponentManager directly. All the functions provided here are meant to be used with a model entity. More...
#include <ignition/gazebo/Model.hh>
 Model (const Model &_model)
 Copy constructor. More...
 Model (gz::sim::Entity _entity=kNullEntity)
 Model (Model &&_model) noexcept
 Move constructor. More...
virtual ~Model ()
gz::sim::Entity CanonicalLink (const EntityComponentManager &_ecm) const
 Get the model's canonical link entity. More...
gz::sim::Entity Entity () const
 Get the entity which this Model is related to. More...
gz::sim::Entity JointByName (const EntityComponentManager &_ecm, const std::string &_name)
 Get the ID of a joint entity which is an immediate child of this model. More...
uint64_t JointCount (const EntityComponentManager &_ecm) const
 Get the number of joints which are immediate children of this model. More...
std::vector< gz::sim::Entity > Joints (const EntityComponentManager &_ecm) const
 Get all joints which are immediate children of this model. More...
gz::sim::Entity LinkByName (const EntityComponentManager &_ecm, const std::string &_name)
 Get the ID of a link entity which is an immediate child of this model. More...
uint64_t LinkCount (const EntityComponentManager &_ecm) const
 Get the number of links which are immediate children of this model. More...
std::vector< gz::sim::Entity > Links (const EntityComponentManager &_ecm) const
 Get all links which are immediate children of this model. More...
std::string Name (const EntityComponentManager &_ecm) const
 Get the model's unscoped name. More...
Model & operator= (const Model &_model)
 Copy assignment operator. More...
Model & operator= (Model &&_model) noexcept
 Move assignment operator. More...
bool SelfCollide (const EntityComponentManager &_ecm) const
 Get whether this model has self-collide enabled. More...
void SetWorldPoseCmd (EntityComponentManager &_ecm, const math::Pose3d &_pose)
 Set a command to change the model's pose. More...
std::string SourceFilePath (const EntityComponentManager &_ecm) const
 Get the source file where this model came from. If empty, the model wasn't loaded directly from a file, probably from an SDF string. More...
bool Static (const EntityComponentManager &_ecm) const
 Get whether this model is static. More...
 Check whether this model correctly refers to an entity that has a components::Model. More...
bool WindMode (const EntityComponentManager &_ecm) const
 Get whether this model has wind enabled. More...
For example, given a model's entity, to find the value of its name component, one could use the entity-component manager (ecm) directly as follows:
Model model(entity); std::string name = model.Name(ecm);
Todo:
(louise) Store the ecm instead of passing it at every API call.
◆ Model() [1/3]
Model ( gz::sim::Entity  _entity = kNullEntity)
[in]_entityModel entity
◆ Model() [2/3]
Model ( const Model &  _model)
Copy constructor.
[in]_modelModel to copy.
◆ Model() [3/3]
Model ( Model &&  _model)
noexcept
Move constructor.
[in]_modelModel to move.
◆ ~Model()
virtual ~Model ( )
◆ CanonicalLink()
gz::sim::Entity CanonicalLink ( const EntityComponentManager &  _ecm) const
Link entity.
◆ Entity()
Model entity.
◆ JointByName()
gz::sim::Entity JointByName ( const EntityComponentManager &  _ecm,
const std::string &  _name
[in]_nameJoint name.
Joint entity.
Todo:
(anyone) Make const
◆ JointCount()
uint64_t JointCount ( const EntityComponentManager &  _ecm) const
Number of joints in this model.
◆ Joints()
std::vector<gz::sim::Entity> Joints ( const EntityComponentManager &  _ecm) const
All joints in this model.
◆ LinkByName()
gz::sim::Entity LinkByName ( const EntityComponentManager &  _ecm,
[in]_nameLink name.
Link entity.
Todo:
(anyone) Make const
◆ LinkCount()
uint64_t LinkCount ( const EntityComponentManager &  _ecm) const
Number of links in this model.
◆ Links()
std::vector<gz::sim::Entity> Links ( const EntityComponentManager &  _ecm) const
All links in this model.
◆ Name()
std::string Name ( const EntityComponentManager &  _ecm) const
Model's name.
◆ operator=() [1/2]
Model& operator= ( const Model &  _model)
Reference to this.
◆ operator=() [2/2]
Model& operator= ( Model &&  _model)
noexcept
[in]_modelModel component to move.
Reference to this.
◆ SelfCollide()
bool SelfCollide ( const EntityComponentManager &  _ecm) const
True if self-colliding.
◆ SetWorldPoseCmd()
void SetWorldPoseCmd ( EntityComponentManager &  _ecm,
const math::Pose3d &  _pose
[in]_poseNew model pose.
◆ SourceFilePath()
std::string SourceFilePath ( const EntityComponentManager &  _ecm) const
Path to the source SDF file.
◆ Static()
bool Static ( const EntityComponentManager &  _ecm) const
True if static.
◆ Valid()
True if it's a valid model in the manager.
◆ WindMode()
bool WindMode ( const EntityComponentManager &  _ecm) const
True if wind mode is on.
