gz/sim/Model.hh
16 */
17 #ifndef GZ_GAZEBO_MODEL_HH_
18 #define GZ_GAZEBO_MODEL_HH_
20 #include <memory>
21 #include <string>
22 #include <vector>
23
24 #include <gz/math/Pose3.hh>
25
26 #include <gz/sim/config.hh>
28 #include <gz/sim/Export.hh>
29 #include <gz/sim/Types.hh>
30
31 namespace ignition
32 {
33  namespace gazebo
34  {
35  // Inline bracket to help doxygen filtering.
36  inline namespace IGNITION_GAZEBO_VERSION_NAMESPACE {
37  // Forward declarations.
38  class IGNITION_GAZEBO_HIDDEN ModelPrivate;
39  //
60  class IGNITION_GAZEBO_VISIBLE Model {
63  public: explicit Model(gz::sim::Entity _entity = kNullEntity);
64
67  public: Model(const Model &_model);
68
71  public: Model(Model &&_model) noexcept;
72
76  public: Model &operator=(Model &&_model) noexcept;
77
81  public: Model &operator=(const Model &_model);
82
84  public: virtual ~Model();
85
88  public: gz::sim::Entity Entity() const;
89
94  public: bool Valid(const EntityComponentManager &_ecm) const;
95
99  public: std::string Name(const EntityComponentManager &_ecm) const;
100
104  public: bool Static(const EntityComponentManager &_ecm) const;
105
109  public: bool SelfCollide(const EntityComponentManager &_ecm) const;
110
114  public: bool WindMode(const EntityComponentManager &_ecm) const;
115
122  const;
123
130  public: gz::sim::Entity JointByName(const EntityComponentManager &_ecm,
131  const std::string &_name);
132
139  public: gz::sim::Entity LinkByName(const EntityComponentManager &_ecm,
140  const std::string &_name);
141
145  public: std::vector<gz::sim::Entity> Joints(
146  const EntityComponentManager &_ecm) const;
147
151  public: std::vector<gz::sim::Entity> Links(
152  const EntityComponentManager &_ecm) const;
153
158  public: uint64_t JointCount(const EntityComponentManager &_ecm) const;
159
164  public: uint64_t LinkCount(const EntityComponentManager &_ecm) const;
165
169  public: void SetWorldPoseCmd(EntityComponentManager &_ecm,
170  const math::Pose3d &_pose);
171
176  const EntityComponentManager &_ecm) const;
177
179  private: std::unique_ptr<ModelPrivate> dataPtr;
180  };
181  }
182  }
183 }
184 #endif
Check whether this model correctly refers to an entity that has a components::Model.
uint64_t Entity
Definition: gz/sim/Entity.hh:59
STL class.
Definition: gz/sim/EntityComponentManager.hh:65
Get whether this model has self-collide enabled.
This class provides wrappers around entities and components which are more convenient and straight-fo...
Definition: gz/sim/Model.hh:60
std::vector< gz::sim::Entity > Joints(const EntityComponentManager &_ecm) const
Get all joints which are immediate children of this model.
STL class.
Component< bool, class WindModeTag > WindMode
A component used to indicate whether an entity is affected by wind.
Definition: gz/sim/components/WindMode.hh:33
Get the number of joints which are immediate children of this model.
std::vector< gz::sim::Entity > Links(const EntityComponentManager &_ecm) const
Get all links which are immediate children of this model.
virtual ~Model()
Component< std::string, class NameTag > Name
This component holds an entity's name. The component has no concept of scoped names nor does it care ...
Definition: gz/sim/components/Name.hh:35
Definition: gz/sim/Model.hh:38
Component< std::string, class SourceFilePathTag > SourceFilePath
This component holds the filepath to the source from which an entity is created. For example,...
Definition: gz/sim/components/SourceFilePath.hh:36
const Entity kNullEntity
Indicates a non-existant or invalid Entity.
Definition: gz/sim/Entity.hh:62
Component< NoData, class CanonicalLinkTag > CanonicalLink
A component that identifies an entity as being a canonical link.
Definition: gz/sim/components/CanonicalLink.hh:33
std::string SourceFilePath(const EntityComponentManager &_ecm) const
Get the source file where this model came from. If empty, the model wasn't loaded directly from a fil...
Get the entity which this Model is related to.
Get the model's unscoped name.
gz::sim::Entity JointByName(const EntityComponentManager &_ecm, const std::string &_name)
Get the ID of a joint entity which is an immediate child of this model.
Component< NoData, class ModelTag > Model
A component that identifies an entity as being a model.
Definition: gz/sim/components/Model.hh:35
void SetWorldPoseCmd(EntityComponentManager &_ecm, const math::Pose3d &_pose)
Set a command to change the model's pose.
Get whether this model has wind enabled.
Model(gz::sim::Entity _entity=kNullEntity)
Component< bool, class StaticTag > Static
A component used to indicate that a model is static (i.e. not moveable).
Definition: gz/sim/components/Static.hh:34
Component< bool, class SelfCollideTag > SelfCollide
A component used to hold a model's self collide property.
Definition: gz/sim/components/SelfCollide.hh:33
gz::sim::Entity LinkByName(const EntityComponentManager &_ecm, const std::string &_name)
Get the ID of a link entity which is an immediate child of this model.
Model & operator=(Model &&_model) noexcept
Move assignment operator.
gz::sim::Entity CanonicalLink(const EntityComponentManager &_ecm) const
Get the model's canonical link entity.
Get the number of links which are immediate children of this model.
Get whether this model is static.
