This class provides wrappers around entities and components which are more convenient and straight-forward to use than dealing with the EntityComponentManager directly. All the functions provided here are meant to be used with a link entity. More...
#include <ignition/gazebo/Link.hh>
 Link (const Link &_link)
 Copy constructor. More...
 Link (gz::sim::Entity _entity=kNullEntity)
 Link (Link &&_link) noexcept
 Move constructor. More...
 ~Link ()
void AddWorldForce (EntityComponentManager &_ecm, const math::Vector3d &_force) const
 Add a force expressed in world coordinates and applied at the center of mass of the link. More...
void AddWorldWrench (EntityComponentManager &_ecm, const math::Vector3d &_force, const math::Vector3d &_torque) const
 Add a wrench expressed in world coordinates and applied to the link at the link's origin. This wrench is applied for one simulation step. More...
gz::sim::Entity CollisionByName (const EntityComponentManager &_ecm, const std::string &_name) const
 Get the ID of a collision entity which is an immediate child of this link. More...
uint64_t CollisionCount (const EntityComponentManager &_ecm) const
 Get the number of collisions which are immediate children of this link. More...
std::vector< gz::sim::Entity > Collisions (const EntityComponentManager &_ecm) const
 Get all collisions which are immediate children of this link. More...
void EnableAccelerationChecks (EntityComponentManager &_ecm, bool _enable=true) const
 By default, Gazebo will not report accelerations for a link, so functions like WorldLinearAcceleration will return nullopt. This function can be used to enable all acceleration checks. More...
void EnableVelocityChecks (EntityComponentManager &_ecm, bool _enable=true) const
 By default, Gazebo will not report velocities for a link, so functions like WorldLinearVelocity will return nullopt. This function can be used to enable all velocity checks. More...
gz::sim::Entity Entity () const
 Get the entity which this Link is related to. More...
bool IsCanonical (const EntityComponentManager &_ecm) const
 Check if this is the canonical link. More...
 Get the link's unscoped name. More...
Link & operator= (const Link &_link)
 Copy assignment operator. More...
Link & operator= (Link &&_link) noexcept
 Move assignment operator. More...
std::optional< Model > ParentModel (const EntityComponentManager &_ecm) const
 Get the parent model. More...
void ResetEntity (gz::sim::Entity _newEntity)
 Reset Entity to a new one. More...
 Check whether this link correctly refers to an entity that has a components::Link. More...
gz::sim::Entity VisualByName (const EntityComponentManager &_ecm, const std::string &_name) const
 Get the ID of a visual entity which is an immediate child of this link. More...
uint64_t VisualCount (const EntityComponentManager &_ecm) const
 Get the number of visuals which are immediate children of this link. More...
std::vector< gz::sim::Entity > Visuals (const EntityComponentManager &_ecm) const
 Get all visuals which are immediate children of this link. More...
bool WindMode (const EntityComponentManager &_ecm) const
 Get whether this link has wind enabled. More...
std::optional< math::Vector3d > WorldAngularVelocity (const EntityComponentManager &_ecm) const
 Get the angular velocity of the link in the world frame. More...
std::optional< math::Pose3d > WorldInertialPose (const EntityComponentManager &_ecm) const
 Get the world pose of the link inertia. More...
std::optional< math::Matrix3d > WorldInertiaMatrix (const EntityComponentManager &_ecm) const
 Get the inertia matrix in the world frame. More...
std::optional< double > WorldKineticEnergy (const EntityComponentManager &_ecm) const
 Get the rotational and translational kinetic energy of the link with respect to the world frame. More...
std::optional< math::Vector3d > WorldLinearAcceleration (const EntityComponentManager &_ecm) const
 Get the linear acceleration of the body in the world frame. More...
std::optional< math::Vector3d > WorldLinearVelocity (const EntityComponentManager &_ecm) const
 Get the linear velocity at the origin of of the link frame expressed in the world frame, using an offset expressed in a body-fixed frame. If no offset is given, the velocity at the origin of the Link frame will be returned. More...
std::optional< math::Vector3d > WorldLinearVelocity (const EntityComponentManager &_ecm, const math::Vector3d &_offset) const
 Get the linear velocity of a point on the body in the world frame, using an offset expressed in a body-fixed frame. More...
std::optional< math::Pose3d > WorldPose (const EntityComponentManager &_ecm) const
 Get the pose of the link frame in the world coordinate frame. More...
For example, given a link's entity, to find the value of its name component, one could use the entity-component manager (ecm) directly as follows:
Link link(entity); std::string name = link.Name(ecm);
◆ Link() [1/3]
Link ( gz::sim::Entity  _entity = kNullEntity)
[in]_entityLink entity
◆ Link() [2/3]
Link ( const Link &  _link)
Copy constructor.
[in]_linkLink to copy.
◆ Link() [3/3]
Link ( Link &&  _link)
noexcept
Move constructor.
[in]_linkLink to move.
◆ ~Link()
~Link ( )
◆ AddWorldForce()
void AddWorldForce ( EntityComponentManager &  _ecm,
const math::Vector3d &  _force
) const
[in]_ecmMutable Entity-component manager.
[in]_forceForce to be applied expressed in world coordinates
◆ AddWorldWrench()
void AddWorldWrench ( EntityComponentManager &  _ecm,
const math::Vector3d &  _force,
const math::Vector3d &  _torque
) const
[in]_torqueTorque to be applied expressed in world coordinates
◆ CollisionByName()
gz::sim::Entity CollisionByName ( const EntityComponentManager &  _ecm,
const std::string &  _name
) const
[in]_nameCollision name.
Collision entity.
◆ CollisionCount()
uint64_t CollisionCount ( const EntityComponentManager &  _ecm) const
Number of collisions in this link.
◆ Collisions()
std::vector<gz::sim::Entity> Collisions ( const EntityComponentManager &  _ecm) const
All collisions in this link.
◆ EnableAccelerationChecks()
void EnableAccelerationChecks ( EntityComponentManager &  _ecm,
bool  _enable = true
) const
[in]_ecmMutable reference to the ECM.
[in]_enableTrue to enable checks, false to disable. Defaults to true.
◆ EnableVelocityChecks()
void EnableVelocityChecks ( EntityComponentManager &  _ecm,
bool  _enable = true
) const
◆ Entity()
Link entity.
◆ IsCanonical()
bool IsCanonical ( const EntityComponentManager &  _ecm) const
True if it is the canonical link.
◆ Name()
std::optional<std::string> Name ( const EntityComponentManager &  _ecm) const
Link's name or nullopt if the entity does not have a components::Name component
◆ operator=() [1/2]
Link& operator= ( const Link &  _link)
Reference to this.
◆ operator=() [2/2]
Link& operator= ( Link &&  _link)
noexcept
[in]_linkLink component to move.
Reference to this.
◆ ParentModel()
std::optional<Model> ParentModel ( const EntityComponentManager &  _ecm) const
Parent Model or nullopt if the entity does not have a components::ParentEntity component.
◆ ResetEntity()
void ResetEntity ( gz::sim::Entity  _newEntity)
[in]_newEntityNew link entity.
◆ Valid()
True if it's a valid link in the manager.
◆ VisualByName()
gz::sim::Entity VisualByName ( const EntityComponentManager &  _ecm,
) const
[in]_nameVisual name.
Visual entity.
◆ VisualCount()
uint64_t VisualCount ( const EntityComponentManager &  _ecm) const
Number of visuals in this link.
◆ Visuals()
std::vector<gz::sim::Entity> Visuals ( const EntityComponentManager &  _ecm) const
All visuals in this link.
◆ WindMode()
bool WindMode ( const EntityComponentManager &  _ecm) const
True if wind mode is on.
◆ WorldAngularVelocity()
std::optional<math::Vector3d> WorldAngularVelocity ( const EntityComponentManager &  _ecm) const
Angular velocity of the link or nullopt if velocity checks aren't enabled.
◆ WorldInertialPose()
std::optional<math::Pose3d> WorldInertialPose ( const EntityComponentManager &  _ecm) const
Inertial pose in world frame or nullopt if the link does not have the components components::WorldPose and components::Inertial.
◆ WorldInertiaMatrix()
std::optional<math::Matrix3d> WorldInertiaMatrix ( const EntityComponentManager &  _ecm) const
Inertia matrix in world frame, returns nullopt if link does not have components components::Inertial and components::WorldPose.
◆ WorldKineticEnergy()
std::optional<double> WorldKineticEnergy ( const EntityComponentManager &  _ecm) const
Kinetic energy in world frame, returns nullopt if link does not have components components::Inertial, components::WorldAngularVelocity, components::WorldLinearVelocity, and components::WorldPose.
◆ WorldLinearAcceleration()
std::optional<math::Vector3d> WorldLinearAcceleration ( const EntityComponentManager &  _ecm) const
Linear acceleration of the body in the world frame or nullopt if acceleration checks aren't enabled.
◆ WorldLinearVelocity() [1/2]
std::optional<math::Vector3d> WorldLinearVelocity ( const EntityComponentManager &  _ecm) const
Linear velocity of the link or nullopt if the velocity checks aren't enabled.
◆ WorldLinearVelocity() [2/2]
std::optional<math::Vector3d> WorldLinearVelocity ( const EntityComponentManager &  _ecm,
const math::Vector3d &  _offset
) const
[in]_offsetOffset of the point from the origin of the Link frame, expressed in the body-fixed frame.
Linear velocity of the point on the body or nullopt if velocity checks aren't enabled.
◆ WorldPose()
std::optional<math::Pose3d> WorldPose ( const EntityComponentManager &  _ecm) const
Absolute Pose of the link or nullopt if the entity does not have a components::WorldPose component.
