BuoyancyEnginePlugin Class Reference
This class provides a simple mechanical bladder which is used to control the buoyancy of an underwater glider. It uses Archimedes' principle to apply an upward force based on the volume of the bladder. It listens to the topic buoyancy_engine or /model/{namespace}/buoyancy_engine topic for the volume of the bladder in cubicmeters. More...
#include <BuoyancyEngine.hh>
 BuoyancyEnginePlugin ()
void Configure (const Entity &_entity, const std::shared_ptr< const sdf::Element > &_sdf, EntityComponentManager &_ecm, EventManager &)
 Configure the system. More...
void PreUpdate (const UpdateInfo &_info, EntityComponentManager &_ecm)
<link_name> - The link which the plugin is attached to [required, string] <namespace> - The namespace for the topic. If empty the plugin will listen on buoyancy_engine otherwise it listens on /model/{namespace}/buoyancy_engine [optional, string] <min_volume> - Minimum volume of the engine [optional, float, default=0.00003m^3] <neutral_volume> - At this volume the engine has neutral buoyancy. Used to estimate the weight of the engine [optional, float, default=0.0003m^3] <default_volume> - The volume which the engine starts at [optional, float, default=0.0003m^3] <max_volume> - Maximum volume of the engine [optional, float, default=0.00099m^3] <max_inflation_rate> - Maximum inflation rate for bladder [optional, float, default=0.000003m^3/s] <fluid_density> - The fluid density of the liquid its suspended in kgm^-3. [optional, float, default=1000kgm^-3] <surface> - The Z height in metres at which the surface of the water is. If not defined then there is no surface [optional, float]
Topics
  • Subscribes to a gz::msgs::Double on buoyancy_engine or /model/{namespace}/buoyancy_engine. This is the set point for the engine.
  • Publishes a gz::msgs::Double on buoyancy_engine or /model/{namespace}/buoyancy_engine/current_volume on the current volume
Examples
To get started run:
gz sim buoyancy_engine.sdf
Enter the following in a separate terminal:
gz topic -t /model/buoyant_box/buoyancy_engine/ -m gz.msgs.Double
-p "data: 0.003"
To see the box float up.
-p "data: 0.001"
To see the box go down. To see the current volume enter:
gz topic -t /model/buoyant_box/buoyancy_engine/current_volume -e
◆ BuoyancyEnginePlugin()
