OdometryPublisher Class Reference
Odometry Publisher which can be attached to any entity in order to periodically publish 2D or 3D odometry data in the form of gz::msgs::Odometry messages. More...
#include <OdometryPublisher.hh>
 OdometryPublisher ()
 ~OdometryPublisher () override=default
 Configure the system. More...
<odom_frame>: Name of the world-fixed coordinate frame for the is {name_of_model}/odom.
<robot_base_frame>: Name of the coordinate frame rigidly attached to the mobile robot base. This element is optional, and the default value is {name_of_model}/base_footprint.
<odom_publish_frequency>: Odometry publication frequency. This element is optional, and the default value is 50Hz.
<odom_topic>: Custom topic on which this system will publish odometry messages. This element is optional, and the default value is /model/{name_of_model}/odometry.
<odom_covariance_topic>: Custom topic on which this system will publish odometry with covariance messages. This element is optional, and the default value is /model/{name_of_model}/odometry_with_covariance.
<tf_topic>: Custom topic on which this system will publish the transform from odom_frame to robot_base_frame. This element is optional, and the default value is /model/{name_of_model}/pose.
<dimensions>: Number of dimensions to represent odometry. Only 2 and 3 dimensional spaces are supported. This element is optional, and the default value is 2.
<xyz_offset>: Position offset relative to the body fixed frame, the default value is 0 0 0. This offset will be added to the odometry message.
<rpy_offset>: Rotation offset relative to the body fixed frame, the default value is 0 0 0. This offset will be added to the odometry message.
<gaussian_noise>: Standard deviation of the Gaussian noise to be added to pose and twist messages. This element is optional, and the default value is 0.
◆ OdometryPublisher()
◆ ~OdometryPublisher()
~OdometryPublisher ( )
overridedefault
◆ PostUpdate()
