OpticalTactilePluginVisualization Class Reference
#include <Visualization.hh>
 OpticalTactilePluginVisualization (std::string &_modelName, gz::math::Vector3d &_sensorSize, double &_forceLength, float &_cameraUpdateRate, gz::math::Pose3f &_depthCameraOffset)
void AddContactToMarkerMsg (gz::msgs::Contact const &_contact, gz::msgs::Marker &_contactsMarkerMsg)
 Add a contact to the marker message representing the contacts from the contact sensor based on physics. More...
void AddNormalForceToMarkerMsgs (gz::msgs::Marker &_positionMarkerMsg, gz::msgs::Marker &_forceMarkerMsg, gz::math::Vector3f &_position, gz::math::Vector3f &_normalForce, gz::math::Pose3f &_sensorWorldPose)
 Create a marker messages representing the normal force computed from depth camera. More...
void RemoveNormalForcesAndContactsMarkers ()
 Remove all normal forces and contact markers. More...
void RequestContactsMarkerMsg (components::ContactSensorData const *_contacts)
 Request the "/marker" service for the contacts marker. More...
void RequestNormalForcesMarkerMsgs (gz::msgs::Marker &_positionMarkerMsg, gz::msgs::Marker &_forceMarkerMsg)
 Request the "/marker" service for the marker messages representing the normal forces. More...
void RequestSensorMarkerMsg (gz::math::Pose3f const &_sensorPose)
 Request the "/marker" service for the sensor marker. This can be helpful when debbuging, given that there shouldn't be a visual tag in the plugin's model. More...
◆ OpticalTactilePluginVisualization()
OpticalTactilePluginVisualization ( std::string &  _modelName,
gz::math::Vector3d &  _sensorSize,
double &  _forceLength,
float &  _cameraUpdateRate,
gz::math::Pose3f &  _depthCameraOffset
[in]_modelNameName of the model to which the sensor is attached
[in]_sensorSizeSize of the contact sensor
[in]_forceLengthValue of the forceLength attribute
[in]_cameraUpdateRateValue of the cameraUpdateRate attribute
[in]_depthCameraOffsetValue of the depthCameraOffset attribute
◆ AddContactToMarkerMsg()
void AddContactToMarkerMsg ( gz::msgs::Contact const &  _contact,
gz::msgs::Marker &  _contactsMarkerMsg
[in]_contactContact to be added
[out]_contactsMarkerMsgMessage for visualizing the contacts
◆ AddNormalForceToMarkerMsgs()
void AddNormalForceToMarkerMsgs ( gz::msgs::Marker &  _positionMarkerMsg,
gz::msgs::Marker &  _forceMarkerMsg,
gz::math::Vector3f &  _position,
gz::math::Vector3f &  _normalForce,
gz::math::Pose3f &  _sensorWorldPose
[out]_positionMarkerMsgMessage for visualizing the contact positions
[out]_forceMarkerMsgMessage for visualizing the contact normal forces
[in]_positionPosition of the normal force referenced to the depth camera's origin
[in]_normalForceValue of the normal force referenced to the depth camera's origin
[in]_sensorWorldPosePose of the plugin's model referenced to the world's origin
◆ RemoveNormalForcesAndContactsMarkers()
void RemoveNormalForcesAndContactsMarkers ( )
◆ RequestContactsMarkerMsg()
void RequestContactsMarkerMsg ( components::ContactSensorData const *  _contacts)
[in]_contactsContacts to visualize
◆ RequestNormalForcesMarkerMsgs()
void RequestNormalForcesMarkerMsgs ( gz::msgs::Marker &  _positionMarkerMsg,
[in]_positionMarkerMsgMessage for visualizing the contact positions
[in]_forceMarkerMsgMessage for visualizing the contact normal forces
◆ RequestSensorMarkerMsg()
void RequestSensorMarkerMsg ( gz::math::Pose3f const &  _sensorPose)
[in]_sensorPosePose of the optical tactile sensor
