Provides a model by which the resource spawner qml plugin pulls and updates from. More...
#include <ResourceSpawner.hh>
Signals
void sizeChanged ()
 Signal used with the totalCount property.
 ResourceModel ()
 ~ResourceModel () override=default
void AddResource (const Resource &_resource)
 Add a resource to the grid view. param[in] _resource The local resource to be added.
void AddResources (std::vector< Resource > &_resources)
 Add a vector of resources to the grid view. param[in] _resource The vector of local resources to be added.
void Clear ()
 Clear the current resource model.
QHash< int, QByteArray > roleNames () const override
void UpdateResourceModel (int index, Resource &_resource)
 Updates the resource at the provided index with the values in the passed in resource.
Public Attributes
int gridIndex = 0
Properties
int totalCount
 Property used to display the total number of resources associated with an owner.
◆ ResourceModel()
ResourceModel ( )
◆ ~ResourceModel()
~ResourceModel ( )
overridedefault
◆ AddResource()
void AddResource ( const Resource &  _resource)
◆ AddResources()
void AddResources ( std::vector< Resource > &  _resources)
◆ Clear()
void Clear ( )
◆ roleNames()
QHash< int, QByteArray > roleNames ( ) const
◆ sizeChanged
void sizeChanged ( )
signal
◆ UpdateResourceModel()
void UpdateResourceModel ( int  index,
[in]indexThe index of the resources within the resource model
[in]_resourceThe resource values with which to update the existing resource
◆ gridIndex
int gridIndex = 0
Property Documentation
◆ totalCount
int totalCount
