LiftDrag Class Reference
The LiftDrag system computes lift and drag forces enabling simulation of aerodynamic robots. More...
#include <LiftDrag.hh>
 LiftDrag ()
 ~LiftDrag () override=default
 Configure the system.
 Documentation inherited.
  • <link_name>: Name of the link affected by the group of lift/drag properties. This can be a scoped name to reference links in nested models.
    entitiesFromScopedName to learn more about scoped names.
  • <air_density>: Density of the fluid this model is suspended in.
  • <radial_symmetry>: True if the shape is aerodynamically radially symmetric about the forward direction.
  • <reversible>: True if the airfoil is symmetric when the inflow is reversed (for example reversible propellers)
  • <area>: Surface area of the link.
  • <a0>: The initial "alpha" or initial angle of attack. a0 is also the y-intercept of the alpha-lift coefficient curve.
  • <cla>: The ratio of the coefficient of lift and alpha slope before stall. Slope of the first portion of the alpha-lift coefficient curve.
  • <cda>: The ratio of the coefficient of drag and alpha slope before stall.
  • <cma>: The ratio of the coefficient of moment and alpha slope before stall.
  • <cp>: Center of pressure. The forces due to lift and drag will be applied here.
  • <forward>: 3-vector representing the forward direction of motion in the link frame.
  • <upward>: 3-vector representing the direction of lift or drag.
  • <alpha_stall>: Angle of attack at stall point; the peak angle of attack.
  • <cla_stall>: The ratio of coefficient of lift and alpha slope after stall. Slope of the second portion of the alpha-lift coefficient curve.
  • <cda_stall>: The ratio of coefficient of drag and alpha slope after stall.
  • <cda_stall>: The ratio of coefficient of moment and alpha slope after stall.
  • <control_joint_name>: Name of joint that actuates a control surface for this lifting body (Optional)
  • <cm_delta>: How much Cm changes with a change in control surface deflection angle
  • <control_joint_rad_to_cl>: How much to change CL per radian of control joint surface angle.
◆ LiftDrag()
LiftDrag ( )
◆ ~LiftDrag()
~LiftDrag ( )
overridedefault
finalvirtual
