Interface for a system that implements optional configuration. More...
#include <System.hh>
| virtual void | Configure (const Entity &_entity, const std::shared_ptr< const sdf::Element > &_sdf, EntityComponentManager &_ecm, EventManager &_eventMgr)=0 |
| Configure the system. | |
Interface for a system that implements optional configuration of the default priority value.
Configure is called after the system is instantiated and all entities and components are loaded from the corresponding SDF world, and before simulation begins execution.
ConfigurePriority is called before the system is instantiated to override System::kDefaultPriority. It can still be overridden by the XML priority element.
◆ Configure()
pure virtual |
Implemented in JointStatePublisher, BuoyancyEnginePlugin, EnvironmentalSensorSystem, Hydrodynamics, LighterThanAirDynamics, Thruster, AirSpeed, LinearBatteryPlugin, CameraVideoRecorder, DetachableJoint, FollowActor, KineticEnergyMonitor, LogVideoRecorder, PerformerDetector, Physics, PythonSystemLoader, SceneBroadcaster, ShaderParam, WindEffects, ICommsModel, AckermannSteering, AdvancedLiftDrag, ApplyJointForce, ApplyLinkWrench, Breadcrumbs, Buoyancy, CommsEndpoint, DiffDrive, DriveToPoseController, DopplerVelocityLogSystem, Elevator, JointController, JointPositionController, JointTrajectoryController, LensFlare, LiftDrag, LogicalAudioSensorPlugin, Magnetometer, MecanumDrive, MulticopterVelocityControl, MulticopterMotorModel, OdometryPublisher, OpticalTactilePlugin, ParticleEmitter, PosePublisher, SpacecraftThrusterModel, TimelinePublisher, TouchPlugin, TrackController, TrackedVehicle, TrajectoryFollower, TriggeredPublisher, UserCommands, VelocityControl, WheelSlip, EnvironmentPreload, Label, Thermal, ThermalSensor, LogPlayback, LogRecord, Sensors, and ModelPhotoShoot.
