Physics Class Reference
Base class for a System. More...
#include <gz/sim/systems/Physics.hh>
 Physics ()
 ~Physics () override
 Configure the system.
System::PriorityType ConfigurePriority () final
 Documentation inherited.
  • <include_entity_names>: Optional. When set to false, the name of colliding entities is not populated in the contacts. Remains true by default.
  • <enforce_fixed_constraint> (optional): Applicable only when the gz-physics bullet-featherstone-plugin is used as the physics engine. If true, the system will enforce the fixed constraint between the child and parent entities of the fixed joint as if the child is 'welded' to the parent. Fixed constraints can be violated, e.g. due to large external forces, so this setting tells the phyics engine to manually correct and maintain the relative pose between the parent and child entities. Defaults to false.
Example
filename="gz-sim-physics-system"
name="systems::Physics">
<contacts>
<include_entity_names>false</include_entity_names>
</contacts>
<enforce_fixed_constraint>false</enforce_fixed_constraint>
◆ Physics()
Physics ( )
◆ ~Physics()
~Physics ( )
finalvirtual
◆ ConfigurePriority()
System::PriorityType ConfigurePriority ( )
finalvirtual
Implements ISystemConfigurePriority.
◆ Reset()
finalvirtual
Implements ISystemReset.
finalvirtual
Implements ISystemUpdate.
