PythonSystemLoader Class Referencefinal
Allows systems to be written in Python. More...
#include <PythonSystemLoader.hh>
 ~PythonSystemLoader () final
 Configure the system.
The convention for a system written in Python supported by the PythonSystemLoader is that it's a Python module providing a get_system function which itself returns an instance of a class that implements the various interfaces in System. The spelling of the interfaces conforms to Python code style guides, so the following name mapping applies
  • configure : Corresponds to System::ISystemConfigure::Configure
  • pre_update : Corresponds to System::ISystemPreUpdate::PreUpdate
  • update : Corresponds to System::ISystemUpdate::Update
  • post_update : Corresponds to System::ISystemPostUpdate::PostUpdate
  • reset : Corresponds to System::ISystemReset::Reset
It is not necessary to implement all the interfaces. PythonSystemLoader will check if the corresponding method is implemented in the Python system and skip it if it's not found.
See examples/scripts/python_api/systems/test_system.py for an example
  • <module_name> : Name of python module to be loaded. The search path includes GZ_SIM_SYSTEM_PLUGIN_PATH as well as PYTHONPATH.
The contents of the <plugin> tag will be available in the configure method of the Python system
◆ ~PythonSystemLoader()
~PythonSystemLoader ( )
final
finalvirtual
◆ PostUpdate()
finalvirtual
finalvirtual
◆ Reset()
finalvirtual
Implements ISystemReset.
finalvirtual
Implements ISystemUpdate.
