TriggeredPublisher Class Reference
The triggered publisher system publishes a user specified message on an output topic in response to an input message that matches user specified criteria. It can also call a user specified service as an output in response to an input message. It currently supports blocking service call. An optional simulation time delay can be used delay message publication. More...
#include <TriggeredPublisher.hh>
 TriggeredPublisher ()=default
 ~TriggeredPublisher () override
 Configure the system.
void DoWork ()
 Thread that handles publishing output messages.
bool MatchInput (const transport::ProtoMsg &_inputMsg)
 Helper function that calls Match on every InputMatcher available.
  • <input>: The tag contains the input message type, topic and matcher information.
    • Attributes:
      • type: Input message type (e.g. gz.msgs.Boolean)
      • topic: Input message topic name
  • <input><match>: Contains configuration for matchers. Multiple <match> tags are possible. An output message is triggered if all Matchers match.
    • Attributes:
      • logic_type("positive" or "negative"): Specifies whether a comparison must succeed or fail in order to trigger an output message. A "positive" value triggers a match when a comparison succeeds. A "negative" value triggers a match when a comparson fails. The default value is "positive"
      • tol: Tolerance for floating point comparisons.
      • field: If specified, only this field inside the input message is compared for a match.
    • Value: String used to construct the protobuf message against which input messages are matched. This is the human-readable representation of a protobuf message as used by gz topic for publishing messages
  • <output>: Contains configuration for output messages: Multiple <output> tags are possible. A message will be published on each output topic for each input that matches.
    • Attributes:
      • type: Output message type (e.g. gz.msgs.Boolean)
      • topic: Output message topic name
    • Value: String used to construct the output protobuf message . This is the human-readable representation of a protobuf message as used by gz topic for publishing messages
  • <delay_ms>: Integer number of milliseconds, in simulation time, to delay publication.
  • <service>: Contains configuration for service to call: Multiple <service> tags are possible. A service will be called for each input that matches.
    • Attributes:
      • name: Service name (e.g. /world/triggered_publisher/set_pose)
      • timeout: Service timeout
      • reqType: Service request message type (e.g. gz.msgs.Pose)
      • repType: Service response message type (e.g. gz.msgs.Empty)
      • reqMsg: String used to construct the service protobuf message.
Examples
  1. Any receipt of a Boolean messages on the input topic triggers an output
    <plugin>
    <input type="gz.msgs.Boolean" topic="/input_topic"/>
    <output type="gz.msgs.Empty" topic="/output_topic"/>
  2. Full match: An output is triggered when a Boolean message with a value of "true" is received
    <plugin>
    <input type="gz.msgs.Boolean" topic="/input_topic">
    <match>
    data: true
    </match>
    </input>
  3. Field match: An output is triggered when a specific field matches
    <plugin>
    <input type="gz.msgs.Vector2d" topic="/input_topic">
    <match field="x">1.0</match>
    <match field="y">2.0</match>
    </input>
The logic_type attribute can be used to negate a match. That is, to trigger an output when the input does not equal the value in <match> For example, the following will trigger an output when the input does not equal 1 AND does not equal 2.
<plugin>
<input type="gz.msgs.Int32" topic="/input_topic">
<match logic_type="negative">1</match>
<match logic_type="negative">2</match>
</input>
Repeated Fields
When a field matcher is used with repeated fields, the content of the repeated field is treated as a set and the comparison operator is set containment. For example, the data field of gz.msgs.Int32_V is a repeated Int32 message. To match an input that contains the values 1 and 2 the following matcher can be used:
<plugin>
<input type="gz.msgs.Int32_V" topic="/input_topic">
<match field="data">1</match>
<match field="data">2</match>
</input>
To match an Int32_V message with the exact contents {1, 2}, the full matcher is used instead
<plugin>
<match>
data: 1
data: 2
</match>
</input>
Limitations
The current implementation of this system does not support specifying a subfield of a repeated field in the "field" attribute. i.e, if field="f1.f2", f1 cannot be a repeated field.
◆ TriggeredPublisher()
TriggeredPublisher ( )
default
◆ ~TriggeredPublisher()
~TriggeredPublisher ( )
◆ DoWork()
void DoWork ( )
◆ MatchInput()
bool MatchInput ( const transport::ProtoMsg &  _inputMsg)
[in]_inputMsgInput message
True if all of the matchers return true
