PerfectComms Class Reference
An example of a comms model. This model always delivers any message to its destination. More...
#include <PerfectComms.hh>
 PerfectComms ()
 This method is called when the system is being configured override this to load any additional params for the comms model.
 This method is called when there is a timestep in the simulator override this to update your data structures as needed.
 ICommsModel ()
 Configure the system.
 This method is called when there is a timestep in the simulator.
◆ PerfectComms()
PerfectComms ( )
◆ Load()
Implements ICommsModel.
◆ Step()
[in]_ecm- Gazebo Sim's ECM.
