PointLight Class Reference
#include <gz/rendering/Light.hh>
virtual ~PointLight ()
virtual ~Light ()
 Get the attenuation range.
 Get the diffuse color.
 Get the light intensity.
 Set the attenuation range.
 Set the diffuse color.
 Set the light intensity.
 Set the specular color.
 Get the specular color.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
◆ ~PointLight()
virtual ~PointLight ( )
