Ogre2.x implementation of the render target class. More...
#include <Ogre2RenderTarget.hh>
virtual ~Ogre2RenderTarget ()
 Get the anti-aliasing level. More...
 Get a pointer to the internal ogre camera. More...
 Copy the render target buffer data to an image. More...
virtual void Destroy () override=0
 Destroy the render target. More...
virtual void Render ()
 Main render call. More...
virtual Ogre::RenderTarget * RenderTarget () const =0
 Get a pointer to the ogre render target. More...
 set the anti-aliasing level More...
 Set the background color of the render target. More...
 Set the ogre camera to use for this render target. More...
- Public Member Functions inherited from BaseRenderTarget< Ogre2Object >
 BaseRenderTarget ()
virtual ~BaseRenderTarget ()
virtual ~RenderTarget ()
static void UpdateRenderPassChain (Ogre::CompositorWorkspace *_workspace, const std::string &_workspaceDefName, const std::string &_baseNode, const std::string &_finalNode, const std::vector< RenderPassPtr > &_renderPasses, bool _recreateNodes)
 Update the render pass chain. More...
virtual void BuildCompositor ()
 Build the comopsitor. More...
virtual void DestroyCompositor ()
 Destroy the compositor. More...
virtual void RebuildCompositor ()
 Rebuild the compositor. More...
 Implementation of the Rebuild function. More...
void RebuildMaterial ()
virtual void RebuildTarget ()=0
 Rebuild the render target. More...
 Update the background color. More...
void UpdateShadowNode ()
 Create a compositor shadow node with the same number of shadow textures as the number of shadow casting lights. More...
- Protected Member Functions inherited from BaseRenderTarget< Ogre2Object >
virtual void Rebuild ()
virtual void Init ()
unsigned int antiAliasing = 4
 Anti-aliasing level. More...
bool colorDirty = true
 Flag to indicate if the render target color has changed. More...
Ogre2RenderTargetMaterialPtr materialApplicator
 Stores the background color of the render target. More...
 Pointer to the internal ogre camera. More...
Ogre::CompositorWorkspace * ogreCompositorWorkspace = nullptr
 Ogre's compositor workspace - the main interface to render into a render target or render texture. More...
std::string ogreCompositorWorkspaceDefName
 Ogre's compositor workspace definition name. More...
- Protected Attributes inherited from BaseRenderTarget< Ogre2Object >
PixelFormat format
unsigned int height
bool renderPassDirty
bool targetDirty
unsigned int width
◆ Ogre2RenderTarget()
Ogre2RenderTarget ( )
◆ ~Ogre2RenderTarget()
virtual ~Ogre2RenderTarget ( )
◆ AntiAliasing()
◆ BackgroundColor()
Implements RenderTarget.
◆ BuildCompositor()
virtual void BuildCompositor ( )
◆ Camera()
virtual Ogre::Camera* Camera ( ) const
Pointer to ogre camera
◆ Copy()
[in]_imageImage to copy the data to
overridepure virtual
Implemented in Ogre2RenderWindow, and Ogre2RenderTexture.
◆ DestroyCompositor()
virtual void DestroyCompositor ( )
◆ PostRender()
virtual void PostRender ( )
Reimplemented from BaseRenderTarget< Ogre2Object >.
Reimplemented in Ogre2RenderTexture.
◆ RebuildCompositor()
virtual void RebuildCompositor ( )
◆ RebuildImpl()
virtual void RebuildImpl ( )
Implements BaseRenderTarget< Ogre2Object >.
◆ RebuildMaterial()
void RebuildMaterial ( )
Ogre2RenderTarget::RebuildImpl()
BaseRenderTarget::Rebuild()
◆ RebuildTarget()
protectedpure virtual
◆ Render()
virtual void Render ( )
Main render call.
◆ RenderTarget()
◆ SetAntiAliasing()
virtual void SetAntiAliasing ( unsigned int  _aa)
[in]_aaAnti-aliasing level
◆ SetBackgroundColor()
virtual void SetBackgroundColor ( math::Color  _color)
[in]_colorColor to set the background to
◆ SetCamera()
virtual void SetCamera ( Ogre::Camera *  _camera)
[in]_cameraPointer to ogre camera
◆ SetMaterial()
void SetMaterial ( MaterialPtr  _material)
[in]_materialThe material to render
◆ UpdateBackgroundColor()
virtual void UpdateBackgroundColor ( )
◆ UpdateRenderPassChain() [1/2]
virtual void UpdateRenderPassChain ( )
◆ UpdateRenderPassChain() [2/2]
static void UpdateRenderPassChain ( Ogre::CompositorWorkspace *  _workspace,
const std::string &  _workspaceDefName,
const std::string &  _baseNode,
const std::string &  _finalNode,
const std::vector< RenderPassPtr > &  _renderPasses,
bool  _recreateNodes
static
◆ UpdateShadowNode()
void UpdateShadowNode ( )
◆ antiAliasing
◆ colorDirty
◆ material
◆ materialApplicator
◆ ogreBackgroundColor
◆ ogreCamera
◆ ogreCompositorWorkspace
Ogre::CompositorWorkspace* ogreCompositorWorkspace = nullptr
◆ ogreCompositorWorkspaceDefName
