Ogre2.x implementation of the render texture class. More...
#include <Ogre2RenderTarget.hh>
virtual ~Ogre2RenderTexture ()
 Destroy the render target. More...
virtual unsigned int GLId () const override
virtual Ogre::RenderTarget * RenderTarget () const override
 Get a pointer to the ogre render target. More...
- Public Member Functions inherited from BaseRenderTexture< Ogre2RenderTarget >
 BaseRenderTexture ()
virtual ~BaseRenderTexture ()
virtual ~RenderTexture ()
virtual ~RenderTarget ()
- Public Member Functions inherited from Ogre2RenderTarget
virtual ~Ogre2RenderTarget ()
 Get the anti-aliasing level. More...
 Get a pointer to the internal ogre camera. More...
 Copy the render target buffer data to an image. More...
virtual void Render ()
 Main render call. More...
 set the anti-aliasing level More...
 Set the background color of the render target. More...
 Set the ogre camera to use for this render target. More...
- Public Member Functions inherited from BaseRenderTarget< Ogre2Object >
 BaseRenderTarget ()
virtual ~BaseRenderTarget ()
virtual void BuildTarget ()
 Build the render texture. More...
virtual void DestroyTarget ()
 Destroy the render texture. More...
 Rebuild the render target. More...
- Protected Member Functions inherited from Ogre2RenderTarget
virtual void BuildCompositor ()
 Build the comopsitor. More...
virtual void DestroyCompositor ()
 Destroy the compositor. More...
virtual void RebuildCompositor ()
 Rebuild the compositor. More...
 Implementation of the Rebuild function. More...
void RebuildMaterial ()
 Update the background color. More...
 Update the render pass chain. More...
void UpdateShadowNode ()
 Create a compositor shadow node with the same number of shadow textures as the number of shadow casting lights. More...
- Protected Member Functions inherited from BaseRenderTarget< Ogre2Object >
virtual void Rebuild ()
virtual void Init ()
Ogre::Texture * ogreTexture = nullptr
 Pointer to the internal ogre render texture object. More...
- Protected Attributes inherited from Ogre2RenderTarget
unsigned int antiAliasing = 4
 Anti-aliasing level. More...
bool colorDirty = true
 Flag to indicate if the render target color has changed. More...
Ogre2RenderTargetMaterialPtr materialApplicator
 Stores the background color of the render target. More...
 Pointer to the internal ogre camera. More...
Ogre::CompositorWorkspace * ogreCompositorWorkspace = nullptr
 Ogre's compositor workspace - the main interface to render into a render target or render texture. More...
std::string ogreCompositorWorkspaceDefName
 Ogre's compositor workspace definition name. More...
- Protected Attributes inherited from BaseRenderTarget< Ogre2Object >
PixelFormat format
unsigned int height
bool renderPassDirty
bool targetDirty
unsigned int width
- Static Public Member Functions inherited from Ogre2RenderTarget
static void UpdateRenderPassChain (Ogre::CompositorWorkspace *_workspace, const std::string &_workspaceDefName, const std::string &_baseNode, const std::string &_finalNode, const std::vector< RenderPassPtr > &_renderPasses, bool _recreateNodes)
◆ Ogre2RenderTexture()
Ogre2RenderTexture ( )
◆ ~Ogre2RenderTexture()
virtual ~Ogre2RenderTexture ( )
◆ BuildTarget()
virtual void BuildTarget ( )
Implements Ogre2RenderTarget.
◆ DestroyTarget()
virtual void DestroyTarget ( )
◆ GLId()
virtual unsigned int GLId ( ) const
Implements RenderTexture.
◆ PostRender()
virtual void PostRender ( )
Reimplemented from Ogre2RenderTarget.
◆ RebuildTarget()
◆ RenderTarget()
◆ ogreTexture
Ogre::Texture* ogreTexture = nullptr
