virtual ~OgreRenderWindow ()
virtual void Destroy ()
- Public Member Functions inherited from BaseRenderWindow< OgreRenderTarget >
 BaseRenderWindow ()
virtual ~BaseRenderWindow ()
virtual double DevicePixelRatio () const
virtual std::string Handle () const
virtual void OnMove ()
virtual void OnResize (const unsigned int _width, const unsigned int _height)
virtual void SetDevicePixelRatio (const double _ratio)
virtual void SetHandle (const std::string &_handle)
- Public Member Functions inherited from RenderWindow
virtual ~RenderWindow ()
virtual double DevicePixelRatio () const =0
virtual std::string Handle () const =0
virtual ~RenderTarget ()
- Public Member Functions inherited from OgreRenderTarget
virtual ~OgreRenderTarget ()
virtual void Render ()
 BaseRenderTarget ()
virtual ~BaseRenderTarget ()
 OgreRenderWindow ()
virtual void BuildTarget ()
virtual void RebuildTarget ()
virtual Ogre::RenderTarget * RenderTarget () const
- Protected Member Functions inherited from OgreRenderTarget
 OgreRenderTarget ()
void RebuildMaterial ()
virtual void Rebuild ()
virtual void Init ()
Ogre::RenderTarget * ogreRenderWindow = nullptr
- Protected Attributes inherited from BaseRenderWindow< OgreRenderTarget >
std::string handle
double ratio
- Protected Attributes inherited from OgreRenderTarget
unsigned int antiAliasing = 4
bool colorDirty = true
PixelFormat format
unsigned int height
bool renderPassDirty
bool targetDirty
unsigned int width
◆ OgreRenderWindow()
OgreRenderWindow ( )
◆ ~OgreRenderWindow()
virtual ~OgreRenderWindow ( )
◆ BuildTarget()
virtual void BuildTarget ( )
Implements OgreRenderTarget.
◆ RebuildTarget()
◆ RenderTarget()
◆ ogreRenderWindow
Ogre::RenderTarget* ogreRenderWindow = nullptr
