Segmentation camera used to label each pixel with a label id. Supports Semantic / Panoptic Segmentation.
More...
| virtual | ~Ogre2SegmentationCamera () |
| | Destructor. More...
| virtual gz::common::ConnectionPtr | ConnectNewSegmentationFrame (std::function< void(const uint8_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override |
| | Connect to the new Segmentation image event. More...
| void | LabelMapFromColoredBuffer (uint8_t *_labelBuffer) const override |
| | Convert the colored map stored in the internal buffer to label IDs map, so users get both the colored map and the corresponding IDs map. This function must be called before the next render loop and the colored map mode must be enabled. More...
| virtual Ogre::Camera * | OgreCamera () const override |
| | Access the Ogre::Camera object. More...
| | Performs any necessary final rendering work. Once rendering is complete the camera will alert any listeners of the new frame event. This function should only be called after a call to Render has successfully been executed. More...
| void | SetBackgroundLabel (int _label) override |
| | Set label for background & unlabeled items in the semantic map. More...
| virtual | ~BaseSegmentationCamera () |
| | Destructor. More...
| virtual const math::Color & | BackgroundColor () const override |
| | Get color for background & unlabeled items in the colored map. More...
| virtual int | BackgroundLabel () const override |
| | Get label for background & unlabeled items in the semantic map. More...
| virtual void | EnableColoredMap (bool _enable) override |
| | Enable Color map mode to generate colored semantics. More...
| virtual bool | IsColoredMap () const override |
| | Check if color map mode is enabled. More...
| virtual uint8_t * | SegmentationData () const override |
| | Get the segmentation image data. If the segmentation type is panoptic, the first two channels are the instance count, and the last channel is the label. More...
| virtual void | SetBackgroundColor (const math::Color &_color) override |
| | Set color for background & unlabeled items in the colored map. More...
| virtual void | SetSegmentationType (SegmentationType _type) override |
| | Set Segmentation Type. More...
| virtual SegmentationType | Type () const override |
| | Get Segmentation Type. More...
| virtual | ~SegmentationCamera () |
| | Destructor. More...
| virtual | ~Camera () |
| | Destructor. More...
| virtual | ~Sensor () |
| | Sensor. More...
| virtual | ~Node () |
| | Destructor. More...
| | Destructor. More...
| virtual | ~BaseCamera () |
| | Right now this is Vulkan-only. This function needs to be called after rendering, and before handling the texture pointer (i.e. by calling RenderTextureMetalId()) so that external APIs (e.g. Qt) can sample the texture. More...
| | Remove all render passes from the camera. More...
| virtual | ~Ogre2Sensor () |
| | Destructor. More...
| virtual | ~BaseSensor () |
| virtual | ~Ogre2Node () |
| | Destructor. More...
| | Get a pointer to the underlying scene node. More...
| virtual | ~BaseNode () |
| virtual | ~Ogre2Object () |
| | Destructor. More...
| virtual | ~BaseObject () |
| virtual | ~Ogre2ObjectInterface () |
| virtual Ogre::MovableObject * | OgreMovableObject (const char *_typename) const |
| | Access to an Ogre::MovableObject. More...
