| virtual | ~Ogre2ThermalCamera () |
| | Destructor. More...
| virtual gz::common::ConnectionPtr | ConnectNewThermalFrame (std::function< void(const uint16_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override |
| | Connect to the new thermal image event. More...
| | Initialize the camera. More...
| virtual Ogre::Camera * | OgreCamera () const override |
| | Access the Ogre::Camera object. More...
| | Render the camera. More...
| | Implementation of the render call. More...
| virtual | ~BaseThermalCamera () |
| | Destructor. More...
| virtual float | AmbientTemperature () const override |
| | Get the ambient temperature of the environment. More...
| virtual float | AmbientTemperatureRange () const override |
| | Get the range of ambient temperature. More...
| virtual float | HeatSourceTemperatureRange () const override |
| | Get the range of temperature variation for all heat sources. More...
| virtual float | LinearResolution () const override |
| | Get the temperature linear resolution. More...
| virtual float | MaxTemperature () const override |
| | Get the maximum temperature the sensor can detect. More...
| virtual float | MinTemperature () const override |
| | Get the minimum temperature the sensor can detect. More...
| virtual void | SetAmbientTemperature (float _ambient) override |
| | Set the ambient temperature of the environment. More...
| virtual void | SetAmbientTemperatureRange (float _range) override |
| | Set the range of ambient temperature. More...
| virtual void | SetHeatSourceTemperatureRange (float _range) override |
| | Set the range of temperature variation for all heat sources. If set, the temperature reading of heat sources will vary within a temperature of +/- range/2 instead of returning a fixed uniform temperature for the entire heat source. More...
| virtual void | SetLinearResolution (float _resolution) override |
| | Set the temperature linear resolution. The thermal image data returned will be temperature in kelvin / resolution. Typical values are 0.01 (10mK), 0.1 (100mK), or 0.04 to simulate 14 bit format. More...
| virtual void | SetMaxTemperature (float _max) override |
| | Set the maximum temperature the sensor can detect. More...
| virtual void | SetMinTemperature (float _min) override |
| | Set the minimum temperature the sensor can detect. More...
| | Destructor. More...
| virtual | ~Camera () |
| | Destructor. More...
| virtual | ~Sensor () |
| | Sensor. More...
| virtual | ~Node () |
| | Destructor. More...
| | Destructor. More...
| virtual | ~BaseCamera () |
| | Right now this is Vulkan-only. This function needs to be called after rendering, and before handling the texture pointer (i.e. by calling RenderTextureMetalId()) so that external APIs (e.g. Qt) can sample the texture. More...
| | Remove all render passes from the camera. More...
| virtual | ~Ogre2Sensor () |
| | Destructor. More...
| virtual | ~BaseSensor () |
| virtual | ~Ogre2Node () |
| | Destructor. More...
| | Get a pointer to the underlying scene node. More...
| virtual | ~BaseNode () |
| virtual | ~Ogre2Object () |
| | Destructor. More...
| virtual | ~BaseObject () |
| virtual | ~Ogre2ObjectInterface () |
| virtual Ogre::MovableObject * | OgreMovableObject (const char *_typename) const |
| | Access to an Ogre::MovableObject. More...
