BaseThermalCamera< T > Class Template Reference
Base implementation of the ThermalCamera class. More...
#include <BaseThermalCamera.hh>
virtual ~BaseThermalCamera ()
virtual float AmbientTemperature () const override
 Get the ambient temperature of the environment.
virtual float AmbientTemperatureRange () const override
 Get the range of ambient temperature.
virtual gz::common::ConnectionPtr ConnectNewThermalFrame (std::function< void(const uint16_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
 Connect to the new thermal image event.
virtual float HeatSourceTemperatureRange () const override
 Get the range of temperature variation for all heat sources.
virtual float LinearResolution () const override
 Get the temperature linear resolution.
virtual float MaxTemperature () const override
 Get the maximum temperature the sensor can detect.
virtual float MinTemperature () const override
 Get the minimum temperature the sensor can detect.
virtual void SetAmbientTemperature (float _ambient) override
 Set the ambient temperature of the environment.
virtual void SetAmbientTemperatureRange (float _range) override
 Set the range of ambient temperature.
virtual void SetHeatSourceTemperatureRange (float _range) override
 Set the range of temperature variation for all heat sources. If set, the temperature reading of heat sources will vary within a temperature of +/- range/2 instead of returning a fixed uniform temperature for the entire heat source.
virtual void SetLinearResolution (float _resolution) override
 Set the temperature linear resolution. The thermal image data returned will be temperature in kelvin / resolution. Typical values are 0.01 (10mK), 0.1 (100mK), or 0.04 to simulate 14 bit format.
virtual void SetMaxTemperature (float _max) override
 Set the maximum temperature the sensor can detect.
virtual void SetMinTemperature (float _min) override
 Set the minimum temperature the sensor can detect.
- Public Member Functions inherited from ThermalCamera
virtual ~ThermalCamera ()
virtual ~Camera ()
virtual void Render ()=0
 Sensor.
 Set visibility mask.
 Get visibility mask.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
virtual ~BaseCamera ()
 Create a render window.
 Get a render passes by index.
 Set the image pixel format.
 BaseCamera ()
float ambient = 0.0f
 Ambient temperature of the environment.
float ambientRange = 0.0f
 Ambient temperature range.
float heatSourceTempRange = 0.0f
 Range of heat source temperature variation.
float maxTemp = gz::math::INF_F
 Maximum temperature.
float minTemp = -gz::math::INF_F
 Minimum temperature.
float resolution = 0.01f
 Linear resolution. Defaults to 10mK.
 Anti-aliasing.
double aspect = 1.3333333
 Aspect ratio.
double farClip = 1000.0
 Far clipping plane distance.
NodePtr followNode
 Target node to follow.
math::Vector3d followOffset
double followPGain = 1.0
bool followWorldFrame = false
 Follow target in world frame.
math::Angle hfov
ImagePtr imageBuffer
double nearClip = 0.01
 Near clipping plane distance.
 Custom projection matrix.
 Camera projection type.
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain = 1.0
bool trackWorldFrame = false
template<class T>
class gz::rendering::BaseThermalCamera< T >
◆ BaseThermalCamera()
template<class T >
BaseThermalCamera ( )
◆ ~BaseThermalCamera()
template<class T >
~BaseThermalCamera ( )
◆ AmbientTemperature()
template<class T >
float AmbientTemperature ( ) const
Ambient temperature in kelvin
Implements ThermalCamera.
◆ AmbientTemperatureRange()
template<class T >
float AmbientTemperatureRange ( ) const
The ambient temperature range. Ambient temperature ranges from (ambient - range/2) to (ambient - range/2)
◆ ConnectNewThermalFrame()
template<class T >
common::ConnectionPtr ConnectNewThermalFrame ( std::function< void(const uint16_t *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
[in]_subscriberSubscriber callback function. The callback function arguments are: <thermal data, width, height, depth, format>
Reimplemented in OgreThermalCamera, and Ogre2ThermalCamera.
◆ HeatSourceTemperatureRange()
template<class T >
float HeatSourceTemperatureRange ( ) const
Temperature variation range
◆ LinearResolution()
template<class T >
float LinearResolution ( ) const
Temperature linear resolution
SetLinearResolution
◆ MaxTemperature()
template<class T >
float MaxTemperature ( ) const
Max temperature in kelvin
SetMaxTemperature
◆ MinTemperature()
template<class T >
float MinTemperature ( ) const
Min temperature in kelvin
SetMinTemperature
◆ SetAmbientTemperature()
template<class T >
void SetAmbientTemperature ( float  _ambient)
[in]_ambientAmbient temperature in kelvin
AmbientTemperature
◆ SetAmbientTemperatureRange()
template<class T >
void SetAmbientTemperatureRange ( float  _range)
[in]_rangeThe ambient temperature ranges from (ambient - range/2) to (ambient + range/2).
◆ SetHeatSourceTemperatureRange()
template<class T >
void SetHeatSourceTemperatureRange ( float  _range)
[in]_rangeTemperature variation range
◆ SetLinearResolution()
template<class T >
void SetLinearResolution ( float  _resolution)
[in]_resolutionTemperature linear resolution
LinearResolution
◆ SetMaxTemperature()
template<class T >
void SetMaxTemperature ( float  _max)
[in]_maxMax temperature in kelvin
MaxTemperature
◆ SetMinTemperature()
template<class T >
void SetMinTemperature ( float  _min)
[in]_minMin temperature in kelvin
MinTemperature
◆ ambient
template<class T >
◆ ambientRange
template<class T >
◆ heatSourceTempRange
template<class T >
◆ maxTemp
template<class T >
◆ minTemp
template<class T >
◆ resolution
template<class T >
