BaseCamera< T > Class Template Referenceabstract
#include <BaseCamera.hh>
virtual ~BaseCamera ()
 Create a render window.
 Get a render passes by index.
 Set the image pixel format.
virtual ~Camera ()
virtual void Render ()=0
 Sensor.
 Set visibility mask.
 Get visibility mask.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 BaseCamera ()
 Anti-aliasing.
double aspect = 1.3333333
 Aspect ratio.
double farClip = 1000.0
 Far clipping plane distance.
NodePtr followNode
 Target node to follow.
math::Vector3d followOffset
double followPGain = 1.0
bool followWorldFrame = false
 Follow target in world frame.
math::Angle hfov
ImagePtr imageBuffer
double nearClip = 0.01
 Near clipping plane distance.
 Custom projection matrix.
 Camera projection type.
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain = 1.0
bool trackWorldFrame = false
◆ BaseCamera()
template<class T >
BaseCamera ( )
◆ ~BaseCamera()
template<class T >
~BaseCamera ( )
◆ AddRenderPass()
template<class T >
Implements Camera.
Reimplemented in OgreWideAngleCamera, Ogre2DepthCamera, and Ogre2WideAngleCamera.
References RenderTarget::AddRenderPass().
◆ AntiAliasing()
template<class T >
unsigned int AntiAliasing ( ) const
Implements Camera.
Reimplemented in OgreCamera, and Ogre2Camera.
◆ AspectRatio()
template<class T >
double AspectRatio ( ) const
Remarks
If SetAspectRatio() gets called with an input <= 0 this function returns the Aspect Ratio autocalculated based on the camera's dimensions.
The camera's aspect ratio. This value is always in range (0; inf) unless the dimensions are invalid (e.g. 0 width or height, NaN resolution, etc)
Implements Camera.
◆ Capture()
template<class T >
void Capture ( Image &  _image)
Implements Camera.
◆ ConnectNewImageFrame()
template<class T >
common::ConnectionPtr ConnectNewImageFrame ( Camera::NewFrameListener  _listener)
[in]_listenerNew camera listener callback
Implements Camera.
◆ Copy()
template<class T >
void Copy ( Image &  _image) const
Implements Camera.
Reimplemented in OgreWideAngleCamera, and Ogre2WideAngleCamera.
References RenderTarget::Copy().
◆ CreateImage()
template<class T >
Image CreateImage ( ) const
A newly allocated Image for storing this cameras images
Implements Camera.
◆ CreateImageBuffer()
template<class T >
void * CreateImageBuffer ( ) const
◆ CreateRenderWindow()
template<class T >
RenderWindowPtr CreateRenderWindow ( )
Implements Camera.
References std::endl(), Scene::Engine(), gzerr, and RenderEngine::Name().
◆ FarClipPlane()
template<class T >
double FarClipPlane ( ) const
Implements Camera.
Reimplemented in OgreDepthCamera, and Ogre2DepthCamera.
◆ FollowOffset()
template<class T >
math::Vector3d FollowOffset ( ) const
Offset of camera from target.
Implements Camera.
◆ FollowPGain()
template<class T >
double FollowPGain ( ) const
P gain for camera following
Implements Camera.
◆ FollowTarget()
template<class T >
NodePtr FollowTarget ( ) const
Target node being tracked.
Implements Camera.
◆ HFOV()
template<class T >
math::Angle HFOV ( ) const
Implements Camera.
◆ ImageFormat()
template<class T >
PixelFormat ImageFormat ( ) const
The image pixel format
Implements Camera.
References RenderTarget::Format().
◆ ImageHeight()
template<class T >
unsigned int ImageHeight ( ) const
The image height in pixels
Implements Camera.
References RenderTarget::Height().
◆ ImageMemorySize()
template<class T >
unsigned int ImageMemorySize ( ) const
The image memory size in bytes
Implements Camera.
References PixelUtil::MemorySize().
◆ ImageWidth()
template<class T >
unsigned int ImageWidth ( ) const
The image width in pixels
Implements Camera.
References RenderTarget::Width().
◆ Load()
template<class T >
void Load ( )
◆ NearClipPlane()
template<class T >
Implements Camera.
◆ PostRender()
template<class T >
void PostRender ( )
Implements Camera.
Reimplemented in OgreDepthCamera, OgreGpuRays, OgreThermalCamera, OgreWideAngleCamera, Ogre2BoundingBoxCamera, Ogre2DepthCamera, Ogre2GpuRays, Ogre2SegmentationCamera, Ogre2ThermalCamera, and Ogre2WideAngleCamera.
References Object::PostRender().
◆ PrepareForExternalSampling()
template<class T >
void PrepareForExternalSampling ( )
Implements Camera.
Reimplemented in Ogre2Camera.
References std::endl(), and gzerr.
template<class T >
void PreRender ( )
◆ Project()
template<class T >
math::Vector2i Project ( const math::Vector3d &  _pt) const
[in]_ptPoint in 3d world space
Point in 2d screen space
Implements Camera.
References Vector2< typename T >::X(), Vector3< typename T >::X(), Vector2< typename T >::Y(), Vector3< typename T >::Y(), and Vector3< typename T >::Z().
◆ ProjectionMatrix()
template<class T >
math::Matrix4d ProjectionMatrix ( ) const
◆ ProjectionType()
template<class T >
CameraProjectionType ProjectionType ( ) const
Implements Camera.
◆ RemoveAllRenderPasses()
template<class T >
void RemoveAllRenderPasses ( )
Implements Camera.
◆ RemoveRenderPass()
template<class T >
Implements Camera.
References RenderTarget::RemoveRenderPass().
◆ RenderPassByIndex()
template<class T >
Implements Camera.
References RenderTarget::RenderPassByIndex().
◆ RenderPassCount()
template<class T >
Implements Camera.
References RenderTarget::RenderPassCount().
◆ RenderTarget()
◆ RenderTextureGLId()
template<class T >
unsigned int RenderTextureGLId ( ) const
Texture Id of type GLuint.
Implements Camera.
◆ RenderTextureMetalId()
template<class T >
void RenderTextureMetalId ( void *  _textureIdPtr) const
Implements Camera.
◆ Reset()
template<class T >
void Reset ( )
◆ SaveFrame()
template<class T >
bool SaveFrame ( const std::string &  _name)
[in]_nameName of the output file
Implements Camera.
◆ SetAntiAliasing()
template<class T >
void SetAntiAliasing ( const unsigned int  _aa)
Implements Camera.
◆ SetAspectRatio()
template<class T >
void SetAspectRatio ( const double  _ratio)
image_height /
image_width
[in]_ratioThe camera's aspect ratio
Implements Camera.
◆ SetFarClipPlane()
template<class T >
void SetFarClipPlane ( const double  _far)
Implements Camera.
Reimplemented in OgreCamera, OgreDepthCamera, Ogre2Camera, and Ogre2DepthCamera.
References std::endl(), gzerr, and std::isfinite().
◆ SetFollowOffset()
template<class T >
void SetFollowOffset ( const math::Vector3d &  _offset)
[in]_offsetOffset distance from target node.
Implements Camera.
◆ SetFollowPGain()
template<class T >
void SetFollowPGain ( const double  _pGain)
[in]_pGainP gain for camera following
Implements Camera.
References gz::math::clamp().
◆ SetFollowTarget()
template<class T >
void SetFollowTarget ( const NodePtr &  _target,
const math::Vector3d &  _offset,
[in]_targetTarget node to follow
[in]_offsetTether the camera at an offset distance from the target node.
[in]_worldFrameTrue to follow the target node at a distance that's fixed in world frame. Default is false which means the camera follows at fixed distance in target node's local frame.
Implements Camera.
◆ SetHFOV()
template<class T >
void SetHFOV ( const math::Angle &  _hfov)
Implements Camera.
◆ SetImageFormat()
template<class T >
void SetImageFormat ( PixelFormat  _format,
bool  _reinterpretable = false
[in]_formatNew image pixel format
[in]_reinterpretableSee RenderTarget::SetFormat
Implements Camera.
References RenderTarget::SetFormat().
◆ SetImageHeight()
template<class T >
void SetImageHeight ( const unsigned int  _height)
[in]_heightNew image height in pixels
Implements Camera.
References RenderTarget::SetHeight().
◆ SetImageWidth()
template<class T >
void SetImageWidth ( const unsigned int  _width)
[in]_widthNew image width in pixels
Implements Camera.
References RenderTarget::SetWidth().
◆ SetMaterial()
template<class T >
void SetMaterial ( const MaterialPtr &  _material)
Implements Camera.
◆ SetNearClipPlane()
template<class T >
void SetNearClipPlane ( const double  _near)
Implements Camera.
◆ SetProjectionMatrix()
template<class T >
void SetProjectionMatrix ( const math::Matrix4d &  _matrix)
Implements Camera.
Reimplemented in OgreCamera, OgreDepthCamera, Ogre2BoundingBoxCamera, Ogre2Camera, Ogre2DepthCamera, Ogre2SegmentationCamera, and Ogre2ThermalCamera.
◆ SetProjectionType()
template<class T >
void SetProjectionType ( CameraProjectionType  _type)
SetProjectionMatrix
Implements Camera.
◆ SetShadowsDirty()
template<class T >
void SetShadowsDirty ( )
Implements Camera.
Reimplemented in Ogre2Camera, and Ogre2DepthCamera.
◆ SetTrackOffset()
template<class T >
void SetTrackOffset ( const math::Vector3d &  _offset)
[in]_offsetPoint offset to track
Implements Camera.
◆ SetTrackPGain()
template<class T >
void SetTrackPGain ( const double  _pGain)
[in]_pGainP gain for camera tracking
Implements Camera.
◆ SetTrackTarget()
template<class T >
void SetTrackTarget ( const NodePtr &  _target,
[in]_targetTarget node to track
[in]_offsetTrack a point that is at an offset relative to target.
[in]_worldFrameIf true, the offset point to track will be treated in world frame and its position relative to the target node remains fixed regardless of the target node's rotation. Default is false, which means the camera tracks the point in target node's local frame.
Implements Camera.
◆ TrackOffset()
template<class T >
math::Vector3d TrackOffset ( ) const
Point offset from target.
Implements Camera.
◆ TrackPGain()
template<class T >
double TrackPGain ( ) const
Implements Camera.
◆ TrackTarget()
template<class T >
NodePtr TrackTarget ( ) const
Implements Camera.
template<class T >
void Update ( )
Implements Camera.
References Scene::PostRender(), and Scene::PreRender().
◆ ViewMatrix()
template<class T >
math::Matrix4d ViewMatrix ( ) const
Camera view matrix
Implements Camera.
References Matrix4< typename T >::SetTranslation(), and Matrix3< typename T >::Transpose().
◆ VisualAt()
template<class T >
VisualPtr VisualAt ( const gz::math::Vector2i &  _mousePos)
Implements Camera.
◆ antiAliasing
template<class T >
Anti-aliasing.
◆ aspect
template<class T >
Aspect ratio.
◆ farClip
template<class T >
◆ followNode
template<class T >
NodePtr followNode
◆ followOffset
template<class T >
◆ followPGain
template<class T >
◆ followWorldFrame
template<class T >
◆ hfov
template<class T >
math::Angle hfov
◆ imageBuffer
template<class T >
◆ nearClip
template<class T >
◆ newFrameEvent
template<class T >
common::EventT<void(const void *, unsigned int, unsigned int, unsigned int, const std::string &)> newFrameEvent
◆ projectionMatrix
template<class T >
◆ projectionType
template<class T >
◆ trackNode
template<class T >
NodePtr trackNode
◆ trackOffset
template<class T >
◆ trackPGain
template<class T >
◆ trackWorldFrame
template<class T >
