Ogre implementation of WideAngleCamera. More...
#include <OgreWideAngleCamera.hh>
virtual ~OgreWideAngleCamera ()
void AddRenderPass (const RenderPassPtr &_pass) override
common::ConnectionPtr ConnectNewWideAngleFrame (std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
void Copy (Image &_image) const override
 Create a texture.
unsigned int EnvTextureSize () const
 Gets the environment texture size.
std::vector< Ogre::Camera * > OgreEnvCameras () const
 Get the list of ogre cameras used to create the cube map for generating the wide angle camera image.
 Render the camera.
math::Vector3d Project3d (const math::Vector3d &_pt) const override
 Project 3D world coordinates to screen coordinates.
void RemoveRenderPass (const RenderPassPtr &_pass) override
 Implementation of the render call.
bool SetBackgroundColor (const math::Color &_color)
 Set the background color of the camera.
void SetEnvTextureSize (int _size)
 Sets environment texture size.
void SetUniformVariables (Ogre::Pass *_pass, float _ratio, float _hfov)
 Set uniform variables of a shader for the provided material technique pass.
 Set visibility mask.
- Public Member Functions inherited from BaseWideAngleCamera< OgreSensor >
virtual ~BaseWideAngleCamera ()
virtual const CameraLens & Lens () const override
 Get the camera lens used by this wide angle camera.
virtual void SetLens (const CameraLens &_lens) override
 Set the camera lens to use for this wide angle camera.
- Public Member Functions inherited from WideAngleCamera
virtual ~WideAngleCamera ()
virtual ~Camera ()
 Sensor.
virtual ~BaseCamera ()
 Create a render window.
 Get a render passes by index.
 Set the image pixel format.
virtual ~OgreSensor ()
virtual ~BaseSensor ()
 Get visibility mask.
virtual ~OgreNode ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
void CreateCamera ()
 Create the camera.
void CreateEnvCameras ()
 Creates a set of 6 cameras pointing in different directions.
void CreateWideAngleTexture () override
 Set the camera's render target.
void DestroyRenderTexture ()
 Destroy render texture created by CreateRenderTexture() Note: It's not virtual.
void notifyMaterialRender (Ogre::uint32 _pass_id, Ogre::MaterialPtr &_material) override
 Callback that is used to set mapping material uniform values, implements Ogre::CompositorInstance::Listener interface.
 Get a pointer to the render target.
void UpdateRenderPassChain ()
 Update render pass chain if changes were made.
- Protected Member Functions inherited from BaseWideAngleCamera< OgreSensor >
 BaseCamera ()
 OgreSensor ()
 BaseSensor ()
 OgreNode ()
- Protected Attributes inherited from BaseWideAngleCamera< OgreSensor >
CameraLens lens
 Camera lens used by this wide angle camera.
 Anti-aliasing.
double aspect = 1.3333333
 Aspect ratio.
double farClip = 1000.0
 Far clipping plane distance.
NodePtr followNode
 Target node to follow.
math::Vector3d followOffset
double followPGain = 1.0
bool followWorldFrame = false
 Follow target in world frame.
math::Angle hfov
ImagePtr imageBuffer
double nearClip = 0.01
 Near clipping plane distance.
 Custom projection matrix.
 Camera projection type.
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain = 1.0
bool trackWorldFrame = false
uint32_t visibilityMask
 Camera's visibility mask.
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreWideAngleCamera()
OgreWideAngleCamera ( )
◆ ~OgreWideAngleCamera()
virtual ~OgreWideAngleCamera ( )
◆ AddRenderPass()
Implements Camera.
◆ ConnectNewWideAngleFrame()
common::ConnectionPtr ConnectNewWideAngleFrame ( std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
[in]_subscriberNew camera listener callback
Reimplemented from BaseWideAngleCamera< OgreSensor >.
◆ Copy()
void Copy ( Image &  _image) const
Implements Camera.
◆ CreateCamera()
void CreateCamera ( )
Create the camera.
◆ CreateEnvCameras()
void CreateEnvCameras ( )
◆ CreateRenderTexture()
Create a texture.
◆ CreateWideAngleTexture()
void CreateWideAngleTexture ( )
◆ DestroyRenderTexture()
void DestroyRenderTexture ( )
◆ EnvTextureSize()
unsigned int EnvTextureSize ( ) const
Texture size
Reimplemented from OgreNode.
◆ notifyMaterialRender()
void notifyMaterialRender ( Ogre::uint32  _pass_id,
Ogre::MaterialPtr &  _material
overrideprotected
[in]_pass_idPass identifier
[in]_materialMaterial whose parameters should be set
◆ OgreEnvCameras()
std::vector< Ogre::Camera * > OgreEnvCameras ( ) const
A list of OGRE cameras
◆ PostRender()
virtual void PostRender ( )
Render the camera.
Implements Camera.
◆ Project3d()
math::Vector3d Project3d ( const math::Vector3d &  _pt) const
[in]_pt3D world coodinates
Screen coordinates. Z is the distance of point from camera optical center.
◆ RemoveAllRenderPasses()
void RemoveAllRenderPasses ( )
Implements Camera.
◆ RemoveRenderPass()
Implements Camera.
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
Pointer to the render target
Implements BaseCamera< T >.
◆ SetBackgroundColor()
bool SetBackgroundColor ( const math::Color &  _color)
[in]_colorColor to set the background to
True if the background color is set successfully, false otherwise
◆ SetEnvTextureSize()
void SetEnvTextureSize ( int  _size)
[in]_sizeTexture size
◆ SetUniformVariables()
void SetUniformVariables ( Ogre::Pass *  _pass,
float  _ratio,
float  _hfov
[in]_passOgre::Pass used for rendering
[in]_ratioFrame aspect ratio
[in]_hfovHorizontal field of view
◆ SetVisibilityMask()
[in]_maskVisibility mask
Implements Sensor.
◆ UpdateRenderPassChain()
void UpdateRenderPassChain ( )
