Depth camera used to render depth data into an image buffer. More...
#include <rendering/ogre/OgreDepthCamera.hh>
virtual ~OgreDepthCamera ()
virtual Ogre::Camera * Camera () const override
 Access the Ogre::Camera object.
virtual gz::common::ConnectionPtr ConnectNewDepthFrame (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
 Connect a to the new depth image signal.
virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
 Connect a to the new rgb point cloud signal.
virtual void CreateDepthTexture () override
 Create a texture which will hold the depth data.
virtual const float * DepthData () const override
 All things needed to get back z buffer for depth data.
double FarClipPlane () const override
 Get the far clip distance.
 Initialize the camera.
double NearClipPlane () const override
 Get the near clip distance.
 Render the camera.
 Implementation of the render call.
 Set the far clip distance.
 Set the near clip distance.
- Public Member Functions inherited from BaseDepthCamera< OgreSensor >
 ~BaseDepthCamera () override
virtual gz::common::ConnectionPtr ConnectNewRGBPointCloud (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)
- Public Member Functions inherited from DepthCamera
virtual ~DepthCamera ()
virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud (std::function< void(const float *_pointCloud, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)> _subscriber)=0
 Connect to the new rgb point cloud signal.
virtual ~Camera ()
 Sensor.
virtual ~BaseCamera ()
 Create a render window.
 Get a render passes by index.
 Set the image pixel format.
virtual ~OgreSensor ()
virtual ~BaseSensor ()
 Set visibility mask.
 Get visibility mask.
virtual ~OgreNode ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
- Public Member Functions inherited from OgreObjectInterface
virtual ~OgreObjectInterface ()
 Access to an Ogre::MovableObject.
 OgreDepthCamera ()
void CreateCamera ()
 Create the camera.
void DestroyDepthTexture ()
 Destroy render texture created by CreateDepthTexture() Note: It's not virtual.
void DestroyPointCloudTexture ()
 Destroy render texture created by CreatePointCloudTexture() Note: It's not virtual.
 Get a pointer to the render target.
void UpdateRenderTarget (OgreRenderTexturePtr _target, Ogre::Material *_material, const std::string &_matName)
 Update a render target.
- Protected Member Functions inherited from BaseDepthCamera< OgreSensor >
 BaseDepthCamera ()
 BaseCamera ()
 OgreSensor ()
 BaseSensor ()
 OgreNode ()
Static Protected Member Functions
static double LimitFOV (const double _fov)
 Limit field of view taking care of using a valid value for an OGRE camera.
bool captureData = false
OgreRenderTexturePtr depthTexture
 Pointer to the depth texture.
Ogre::Viewport * depthViewport = nullptr
 Pointer to the depth viewport.
bool newData = false
 Communicates that a frams was rendered.
Ogre::Camera * ogreCamera
 Pointer to the ogre camera.
 Anti-aliasing.
double aspect = 1.3333333
 Aspect ratio.
double farClip = 1000.0
 Far clipping plane distance.
NodePtr followNode
 Target node to follow.
math::Vector3d followOffset
double followPGain = 1.0
bool followWorldFrame = false
 Follow target in world frame.
math::Angle hfov
ImagePtr imageBuffer
double nearClip = 0.01
 Near clipping plane distance.
 Custom projection matrix.
 Camera projection type.
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain = 1.0
bool trackWorldFrame = false
uint32_t visibilityMask
 Camera's visibility mask.
OgreNodeStorePtr children
OgreNodePtr parent
- Public Types inherited from DepthCamera
◆ OgreDepthCamera()
OgreDepthCamera ( )
◆ ~OgreDepthCamera()
virtual ~OgreDepthCamera ( )
◆ Camera()
virtual Ogre::Camera * Camera ( ) const
Implements OgreObjectInterface.
◆ ConnectNewDepthFrame()
virtual gz::common::ConnectionPtr ConnectNewDepthFrame ( std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
Reimplemented from BaseDepthCamera< OgreSensor >.
◆ ConnectNewRgbPointCloud()
virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud ( std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
◆ CreateCamera()
void CreateCamera ( )
Create the camera.
◆ CreateDepthTexture()
virtual void CreateDepthTexture ( )
◆ DepthData()
virtual const float * DepthData ( ) const
The z-buffer as a float array
◆ DestroyDepthTexture()
void DestroyDepthTexture ( )
◆ DestroyPointCloudTexture()
void DestroyPointCloudTexture ( )
◆ FarClipPlane()
double FarClipPlane ( ) const
Far clip distance. A value of zero is returned if the ogre camera has not been created.
Implements Camera.
Reimplemented from OgreNode.
◆ LimitFOV()
static double LimitFOV ( const double  _fov)
staticprotected
[in]_fovexpected field of view
valid field of view
◆ NearClipPlane()
Near clip distance. A value of zero is returned if the ogre camera has not been created.
Implements Camera.
◆ PostRender()
virtual void PostRender ( )
Render the camera.
Implements Camera.
◆ ProjectionMatrix()
Camera projection matrix
Implements Camera.
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
Pointer to the render target
Implements BaseCamera< T >.
◆ SetFarClipPlane()
[in]_farfar clip distance
Implements Camera.
◆ SetNearClipPlane()
[in]_nearNear clip distance
Implements Camera.
◆ SetProjectionMatrix()
Implements Camera.
◆ UpdateRenderTarget()
void UpdateRenderTarget ( OgreRenderTexturePtr  _target,
Ogre::Material *  _material,
const std::string &  _matName
[in]_targetRender target to update
[in]_materialMaterial to use
[in]_matNameMaterial name
◆ captureData
◆ depthTexture
◆ depthViewport
Ogre::Viewport* depthViewport = nullptr
◆ newData
◆ ogreCamera
Ogre::Camera* ogreCamera
