DepthCamera Class Referenceabstract
#include <DepthCamera.hh>
Public Types
virtual ~DepthCamera ()
virtual gz::common::ConnectionPtr ConnectNewDepthFrame (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)=0
 Connect to the new depth image signal.
virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud (std::function< void(const float *_pointCloud, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)> _subscriber)=0
 Connect to the new rgb point cloud signal.
virtual void CreateDepthTexture ()=0
 Create a texture which will hold the depth data.
virtual const float * DepthData () const =0
 All things needed to get back z buffer for depth data.
virtual ~Camera ()
 Create a render window.
virtual void PrepareForExternalSampling ()=0
virtual void Render ()=0
 Get a render passes by index.
virtual void RenderTextureMetalId (void *_textureIdPtr) const =0
virtual void SetImageFormat (PixelFormat _format, bool _reinterpretable=false)=0
 Set the image pixel format.
virtual void Update ()=0
virtual VisualPtr VisualAt (const gz::math::Vector2i &_mousePos)=0
 Sensor.
 Set visibility mask.
 Get visibility mask.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
Member Typedef Documentation
◆ NewFrameListener
typedef std::function<void(const void*, unsigned int, unsigned int, unsigned int, const std::string&)> NewFrameListener
◆ ~DepthCamera()
virtual ~DepthCamera ( )
◆ ConnectNewDepthFrame()
virtual gz::common::ConnectionPtr ConnectNewDepthFrame ( std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
Implemented in BaseDepthCamera< T >, BaseDepthCamera< Ogre2Sensor >, BaseDepthCamera< OgreSensor >, OgreDepthCamera, and Ogre2DepthCamera.
◆ ConnectNewRgbPointCloud()
virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud ( std::function< void(const float *_pointCloud, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)>  _subscriber)
[in]_subscriberSubscriber callback function The arguments of the callback function are: _pointCloud Point cloud data. Each point is represented by four 32 bit floating point values [X, Y, Z, RGBA]. The last field can be decoded into 4 unsigned 8 bit color values: uint32_t *rgba = reinterpret_cast<uint32_t *>(&_rgba) r = static_cast<uint8_t>(*rgba >> 24 & 0xFF); g = static_cast<uint8_t>(*rgba >> 16 & 0xFF); b = static_cast<uint8_t>(*rgba >> 8 & 0xFF); a = static_cast<uint8_t>(*rgba >> 0 & 0xFF); _width Point cloud image width _height Point cloud image height _depth Point cloud image depth _format Point cloud image format
◆ CreateDepthTexture()
virtual void CreateDepthTexture ( )
◆ DepthData()
virtual const float * DepthData ( ) const
The z-buffer as a float array
