Ogre implementation of WideAngleCamera. More...
#include <Ogre2WideAngleCamera.hh>
virtual ~Ogre2WideAngleCamera () override
void AddRenderPass (const RenderPassPtr &_pass) override
MaterialPtr BackgroundMaterial () const
 Get the background material of this camera.
Ogre::Ray CameraToViewportRay (const math::Vector2d &_screenPos, uint32_t _faceIdx)
 It's the same as calling ogreCamera->getCameraToViewportRay but for the specific _faceIdx.
common::ConnectionPtr ConnectNewWideAngleFrame (std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
void Copy (Image &_image) const override
 Create a texture.
void DestroyTextures ()
 Destroys all textures and workspaces, possibly for recreation.
uint32_t EnvTextureSize () const
 Gets the environment texture size.
 Render the camera.
math::Vector3d Project3d (const math::Vector3d &_pt) const override
 Project 3D world coordinates to screen coordinates.
void RemoveRenderPass (const RenderPassPtr &_pass) override
 Implementation of the render call.
void SetBackgroundMaterial (MaterialPtr _material)
 Set the background material of this camera.
void SetEnvTextureSize (uint32_t _size)
 Sets environment texture size.
- Public Member Functions inherited from BaseWideAngleCamera< Ogre2Sensor >
virtual ~BaseWideAngleCamera ()
virtual const CameraLens & Lens () const override
 Get the camera lens used by this wide angle camera.
virtual void SetLens (const CameraLens &_lens) override
 Set the camera lens to use for this wide angle camera.
- Public Member Functions inherited from WideAngleCamera
virtual ~WideAngleCamera ()
virtual ~Camera ()
 Sensor.
virtual ~BaseCamera ()
 Create a render window.
 Get a render passes by index.
 Set the image pixel format.
virtual ~Ogre2Sensor ()
virtual ~BaseSensor ()
 Set visibility mask.
 Get visibility mask.
virtual ~Ogre2Node ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
void CreateCamera ()
 Create the camera.
void CreateFacesWorkspaces (bool _withMsaa)
 Creates the workspaces & their definitions.
void CreateStitchWorkspace ()
 Creates the stitch workspaces & their definitions.
void CreateStitchWorkspaceDefinition ()
 Creates the workspace definition for stitch (final) pass, including effects.
void CreateWideAngleTexture () override
 Set the camera's render target.
void CreateWorkspaceDefinition (bool _withMsaa)
 Creates the workspace definition, including effects.
void DestroyFacesWorkspaces ()
 Destroys the workspaces & their definitions.
void DestroyRenderTexture ()
 Destroy render texture created by CreateRenderTexture() Note: It's not virtual.
void DestroyStitchWorkspace ()
 Destroys the stitch workspaces & their definitions.
bool HasTempStitchTexture () const
 Returns true if we have a temp texture for Render passes with WideAngleCameraAfterStitching = true.
bool NeedsTempStitchTexture () const
 Returns what HasTempStitchTexture() should return.
 Get a pointer to the render target.
void SetupMSAA (Ogre::CompositorManager2 *_ogreCompMgr, uint8_t _msaa)
 Changes the Compositor Definition to use the MSAA settings we need. Do not call this if not using MSAA.
uint32_t TempStitchTextureChannel () const
void UpdateRenderPasses ()
 Checks if workspace nodes need to be updated since render passes can be toggled at any point.
std::string WorkspaceDefinitionName (uint32_t _faceIdx) const
 Returns the workspace name. It's unique for each camera.
std::string WorkspaceFinalPassDefinitionName () const
 Returns the workspace name for the final pass that stitches all faces.
- Protected Member Functions inherited from BaseWideAngleCamera< Ogre2Sensor >
 BaseCamera ()
 Ogre2Sensor ()
 BaseSensor ()
 Ogre2Node ()
 Set the parent node.
- Protected Attributes inherited from BaseWideAngleCamera< Ogre2Sensor >
CameraLens lens
 Camera lens used by this wide angle camera.
 Anti-aliasing.
double aspect = 1.3333333
 Aspect ratio.
double farClip = 1000.0
 Far clipping plane distance.
NodePtr followNode
 Target node to follow.
math::Vector3d followOffset
double followPGain = 1.0
bool followWorldFrame = false
 Follow target in world frame.
math::Angle hfov
ImagePtr imageBuffer
double nearClip = 0.01
 Near clipping plane distance.
 Custom projection matrix.
 Camera projection type.
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain = 1.0
bool trackWorldFrame = false
uint32_t visibilityMask
 Camera's visibility mask.
Ogre2NodeStorePtr children
 A list of child nodes.
Ogre2NodePtr parent
 Pointer to the ogre scene.
◆ Ogre2WideAngleCamera()
Ogre2WideAngleCamera ( )
◆ ~Ogre2WideAngleCamera()
virtual ~Ogre2WideAngleCamera ( )
◆ AddRenderPass()
Implements Camera.
◆ BackgroundMaterial()
MaterialPtr BackgroundMaterial ( ) const
background material
◆ CameraToViewportRay()
Ogre::Ray CameraToViewportRay ( const math::Vector2d &  _screenPos,
uint32_t  _faceIdx
_screenPosScreen space position
_faceIdxFace index in range [0; 6). See RayQuery::SetFromCamera for what each value means
Ogre Ray pointing towards screenPos from the given face idx
◆ ConnectNewWideAngleFrame()
common::ConnectionPtr ConnectNewWideAngleFrame ( std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
[in]_subscriberNew camera listener callback
Reimplemented from BaseWideAngleCamera< Ogre2Sensor >.
◆ Copy()
void Copy ( Image &  _image) const
Implements Camera.
◆ CreateCamera()
void CreateCamera ( )
Create the camera.
◆ CreateFacesWorkspaces()
void CreateFacesWorkspaces ( bool  _withMsaa)
[in]_withMsaaWhether the version we're retrieving is the MSAA
◆ CreateRenderTexture()
Create a texture.
◆ CreateStitchWorkspace()
void CreateStitchWorkspace ( )
◆ CreateStitchWorkspaceDefinition()
void CreateStitchWorkspaceDefinition ( )
◆ CreateWideAngleTexture()
void CreateWideAngleTexture ( )
◆ CreateWorkspaceDefinition()
void CreateWorkspaceDefinition ( bool  _withMsaa)
[in]_withMsaaWhether the camera is using MSAA
◆ DestroyFacesWorkspaces()
void DestroyFacesWorkspaces ( )
◆ DestroyRenderTexture()
void DestroyRenderTexture ( )
◆ DestroyStitchWorkspace()
void DestroyStitchWorkspace ( )
◆ DestroyTextures()
void DestroyTextures ( )
◆ EnvTextureSize()
uint32_t EnvTextureSize ( ) const
Texture size
◆ HasTempStitchTexture()
bool HasTempStitchTexture ( ) const
See description.
Reimplemented from Ogre2Node.
◆ NeedsTempStitchTexture()
bool NeedsTempStitchTexture ( ) const
True if there are RenderPases with WideAngleCameraAfterStitching = true. False otherwise.
◆ PostRender()
virtual void PostRender ( )
Render the camera.
Implements Camera.
◆ Project3d()
math::Vector3d Project3d ( const math::Vector3d &  _pt) const
[in]_pt3D world coordinates
Screen coordinates. Z is the distance of point from camera optical center.
◆ RemoveAllRenderPasses()
void RemoveAllRenderPasses ( )
Implements Camera.
◆ RemoveRenderPass()
Implements Camera.
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
Pointer to the render target
Implements BaseCamera< T >.
◆ SetBackgroundMaterial()
void SetBackgroundMaterial ( MaterialPtr  _material)
[in]_materialMaterial to set the background to
◆ SetEnvTextureSize()
void SetEnvTextureSize ( uint32_t  _size)
[in]_sizeTexture size
◆ SetupMSAA()
void SetupMSAA ( Ogre::CompositorManager2 *  _ogreCompMgr,
uint8_t  _msaa
[in]_ogreCompMgrOgre's Compositor Manager
[in]_msaaValue in range [2; 256)
◆ TempStitchTextureChannel()
uint32_t TempStitchTextureChannel ( ) const
Returns which channel kStichTmpTexture should be in. Depends on whether number of render passes with RenderPass::WideAngleCameraAfterStitching == true is odd or even
◆ UpdateRenderPasses()
void UpdateRenderPasses ( )
◆ WorkspaceDefinitionName()
std::string WorkspaceDefinitionName ( uint32_t  _faceIdx) const
[in]_faceIdxFace index in range [0; 6)
Workspace definition's name
◆ WorkspaceFinalPassDefinitionName()
std::string WorkspaceFinalPassDefinitionName ( ) const
