BoundingBoxCamera Class Referenceabstract
Poseable BoundingBox camera used for rendering bounding boxes of objects in the scene. More...
#include <BoundingBoxCamera.hh>
virtual ~BoundingBoxCamera ()
virtual const std::vector< BoundingBox > & BoundingBoxData () const =0
 Get the BoundingBox data.
virtual gz::common::ConnectionPtr ConnectNewBoundingBoxes (std::function< void(const std::vector< BoundingBox > &)> _subscriber)=0
 Connect to the new BoundingBox info.
virtual void DrawBoundingBox (unsigned char *_data, const math::Color &_color, const BoundingBox &_box) const =0
 Draw a bounding box on the given image.
virtual void SetBoundingBoxType (BoundingBoxType _type)=0
 Set BoundingBox Type (Visible / Full)
virtual BoundingBoxType Type () const =0
 Get the BoundingBox Type (Visible / Full)
virtual ~Camera ()
 Create a render window.
virtual void PrepareForExternalSampling ()=0
virtual void Render ()=0
 Get a render passes by index.
virtual void RenderTextureMetalId (void *_textureIdPtr) const =0
virtual void SetImageFormat (PixelFormat _format, bool _reinterpretable=false)=0
 Set the image pixel format.
virtual void Update ()=0
virtual VisualPtr VisualAt (const gz::math::Vector2i &_mousePos)=0
 Sensor.
 Set visibility mask.
 Get visibility mask.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
gz/rendering/BoundingBoxCamera.hh
◆ ~BoundingBoxCamera()
virtual ~BoundingBoxCamera ( )
◆ BoundingBoxData()
virtual const std::vector< BoundingBox > & BoundingBoxData ( ) const
Buffer of bounding boxes info (label, minX, minY, maxX, maxY). If the camera's bounding box type is 3D, minZ and maxZ are also defined)
Implemented in BaseBoundingBoxCamera< T >, BaseBoundingBoxCamera< Ogre2Sensor >, and Ogre2BoundingBoxCamera.
◆ ConnectNewBoundingBoxes()
virtual gz::common::ConnectionPtr ConnectNewBoundingBoxes ( std::function< void(const std::vector< BoundingBox > &)>  _subscriber)
◆ DrawBoundingBox()
virtual void DrawBoundingBox ( unsigned char *  _data,
const math::Color &  _color,
const BoundingBox &  _box
) const
[in]_databuffer containing the image data
[in]_colorColor of the bounding box to be drawn
[in]_boxbounding box to be drawn
Implemented in Ogre2BoundingBoxCamera, BaseBoundingBoxCamera< T >, and BaseBoundingBoxCamera< Ogre2Sensor >.
◆ SetBoundingBoxType()
virtual void SetBoundingBoxType ( BoundingBoxType  _type)
[in]_typeBoundingBox Type (Visible / Full)
◆ Type()
virtual BoundingBoxType Type ( ) const
