#include <OgreJointVisual.hh>
virtual ~OgreJointVisual ()
- Public Member Functions inherited from BaseJointVisual< OgreVisual >
virtual ~BaseJointVisual ()
 Get the arrow visual which represents the axis attached to the child.
virtual gz::math::Vector3d Axis () const override
 Get axis vector.
virtual gz::math::Vector3d ParentAxis () const override
 Get parent axis vector.
 Get the JointVisual which is attached to the parent.
virtual void SetAxis (const gz::math::Vector3d &_axis, bool _useParentFrame) override
 Create an axis and attach it to the joint visual.
virtual void SetParentAxis (const gz::math::Vector3d &_axis, const std::string &_parentName, bool _useParentFrame) override
 Create a parent axis for hinge2 and universal joint types and attach it to the joint visual.
 Set type for joint visual.
 Get joint visual type.
virtual bool UpdateAxis (const gz::math::Vector3d &_axis, bool _useParentFrame) override
 Update an axis' arrow visual.
virtual bool UpdateParentAxis (const gz::math::Vector3d &_axis, bool _useParentFrame) override
 Update the parent axis' arrow visual if it exists.
virtual ~JointVisual ()
virtual ~OgreVisual ()
 Set visibility flags.
 Enable or disable wireframe.
virtual ~BaseVisual ()
 Add visibility flags.
 Get the local pose.
 Remove visibility flags.
 Set the local pose.
 Get visibility flags.
virtual ~OgreNode ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 OgreJointVisual ()
- Protected Member Functions inherited from BaseJointVisual< OgreVisual >
 BaseJointVisual ()
void CreateAxis ()
 Helper function to create axis visual.
void CreateParentAxis ()
 Helper function to create parent axis visual.
void ScaleToChild ()
 Scale the joint visual according to the joint's child.
void UpdateAxisImpl (ArrowVisualPtr _arrowVisual, const gz::math::Vector3d &_axis, bool _useParentFrame)
 Implementation for updating an axis' arrow visual.
 OgreVisual ()
 BaseVisual ()
 OgreNode ()
- Protected Attributes inherited from BaseJointVisual< OgreVisual >
ArrowVisualPtr arrowVisual
 The visual representing the one joint axis. There can be only one axis visual per joint visual, so joints with two axes have a 2nd JointVisual with its own arrowVisual.
gz::math::Vector3d axis
 Joint visual axis vector.
AxisVisualPtr axisVisual
 The joint's XYZ frame visual.
bool dirtyAxis
 Flag to indicate axis data has changed.
bool dirtyJointType
 Flag to indicate joint visual type has changed.
bool dirtyParentAxis
 Flag to indicate parent axis data has changed.
std::string jointParentName
 Joint parent name.
 Type of joint visualization.
gz::math::Vector3d parentAxis
 Parent axis vector.
bool parentAxisUseParentFrame
 Flag to indicate whether parent axis vector is expressed in joint parent frame.
JointVisualPtr parentAxisVis
 Second joint visual for hinge2 and universal joints. It is a simplified visual without an XYZ frame.
gz::math::Vector3d scaleToChild
 Scale based on the size of the joint's child.
bool updateAxis
 Flag to update the axis visual.
bool updateParentAxis
 Flag to update the parent axis visual.
bool useParentFrame
 Flag to indicate whether axis vector is expressed in joint parent frame.
uint32_t visibilityFlags
 Visual's visibility flags.
bool wireframe
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreJointVisual()
OgreJointVisual ( )
◆ ~OgreJointVisual()
virtual ~OgreJointVisual ( )
