virtual ~OgreRenderTexture ()
virtual void Buffer (float *buffer)
virtual unsigned int GLId () const override
 Returns the OpenGL texture Id. A valid Id is returned only.
virtual Ogre::RenderTarget * RenderTarget () const override
- Public Member Functions inherited from BaseRenderTexture< OgreRenderTarget >
 BaseRenderTexture ()
 ~BaseRenderTexture () override
virtual void MetalId (void *_textureIdPtr) const override
 Gets the Metal texture id. A valid Id is obtained only if this is an Metal render texture. The pointer set by this function must be released to an id<MTLTexture> using CFBridgingRelease.
virtual ~RenderTexture ()
virtual ~RenderTarget ()
- Public Member Functions inherited from OgreRenderTarget
virtual ~OgreRenderTarget ()
 Write rendered image to given Image. The RenderTarget will convert the underlying image to the specified format listed in the given Image. However if the given image is not of the correct size no work will be done. Calling this function before an image has been rendered will result in undefined behavior.
virtual void Render ()
 Set a material to render on every object. This method is used for special cases like the render target of a depth camera.
 Set visibility mask for the viewport associated with this render target.
 BaseRenderTarget ()
 ~BaseRenderTarget () override
virtual bool Reinterpretable () const override
 See SetFormat()
 Remove all render passes from the render target.
 Get a render pass by index.
virtual void SetFormat (PixelFormat _format, bool _reinterpretable=false) override
virtual void BuildTarget ()
virtual void DestroyTarget ()
- Protected Member Functions inherited from OgreRenderTarget
 OgreRenderTarget ()
void RebuildMaterial ()
 Re-initializes render target material to apply a material to everything in the scene. Does nothing if no material has been set.
 Update render pass chain if changes were made.
virtual void Rebuild ()
virtual void Init ()
Ogre::Texture * ogreTexture = nullptr
- Protected Attributes inherited from OgreRenderTarget
unsigned int antiAliasing = 4
bool colorDirty = true
 a material used by for the render target
 Helper class that applies the material to the render target.
 visibility mask associated with this render target
PixelFormat format
unsigned int height
bool reinterpretable
bool renderPassDirty
 Flag to indicate if render pass need to be rebuilt.
 A chain of render passes applied to the render target.
bool targetDirty
unsigned int width
◆ OgreRenderTexture()
OgreRenderTexture ( )
◆ ~OgreRenderTexture()
virtual ~OgreRenderTexture ( )
◆ Buffer()
virtual void Buffer ( float *  buffer)
◆ BuildTarget()
virtual void BuildTarget ( )
◆ DestroyTarget()
virtual void DestroyTarget ( )
◆ GLId()
virtual unsigned int GLId ( ) const
Reimplemented from BaseRenderTexture< OgreRenderTarget >.
◆ PostRender()
virtual void PostRender ( )
◆ RebuildTarget()
Implements OgreRenderTarget.
◆ RenderTarget()
virtual Ogre::RenderTarget * RenderTarget ( ) const
◆ ogreTexture
Ogre::Texture* ogreTexture = nullptr
