SceneManager Class Reference
Scene manager class for loading and managing objects in the scene. More...
#include <SceneManager.hh>
 SceneManager ()
 ~SceneManager ()
std::map< std::string, math::Matrix4d > ActorMeshAnimationAt (Entity _id, std::chrono::steady_clock::duration _time) const
 Get the animation of actor mesh given an id. More...
rendering::MeshPtr ActorMeshById (Entity _id) const
 Get a rendering mesh given an id. More...
bool AddSensor (Entity _gazeboId, const std::string &_sensorName, Entity _parentGazeboId=0)
 Ignition sensors is the one responsible for adding sensors to the scene. Here we just keep track of it and make sure it has the correct parent. More...
rendering::VisualPtr CreateActor (Entity _id, const sdf::Actor &_actor, Entity _parentId=0)
 Create an actor. More...
rendering::VisualPtr CreateCollision (Entity _id, const sdf::Collision &_collision, Entity _parentId=0)
 Create a collision visual. More...
rendering::LightPtr CreateLight (Entity _id, const sdf::Light &_light, Entity _parentId)
 Create a light. More...
rendering::VisualPtr CreateLink (Entity _id, const sdf::Link &_link, Entity _parentId=0)
 Create a link. More...
rendering::VisualPtr CreateModel (Entity _id, const sdf::Model &_model, Entity _parentId=0)
 Create a model. More...
rendering::VisualPtr CreateVisual (Entity _id, const sdf::Visual &_visual, Entity _parentId=0)
 Create a visual. More...
Entity EntityFromNode (const rendering::NodePtr &_node) const
 Get the entity for a given node. More...
bool HasEntity (Entity _id) const
 Check if entity exists. More...
rendering::NodePtr NodeById (Entity _id) const
 Get a rendering node given an entity id. More...
void RemoveEntity (Entity _id)
 Remove an entity by id. More...
 Get the scene. More...
void SetScene (rendering::ScenePtr _scene)
 Set the scene to manage. More...
void SetWorldId (Entity _id)
 Set the world's ID. More...
rendering::NodePtr TopLevelNode (const rendering::NodePtr &_node) const
 Get the top level node for the given node, which is the ancestor which is a direct child to the root visual. Usually, this will be a model or a light. More...
rendering::VisualPtr TopLevelVisual (rendering::VisualPtr _visual) const
 Get the top level visual for the given visual, which is the ancestor which is a direct child to the root visual. Usually, this will be a model or a light. More...
rendering::VisualPtr VisualById (Entity _id)
 Retrieve visual. More...
Entity WorldId () const
 Get the world's ID. More...
◆ SceneManager()
◆ ~SceneManager()
◆ ActorMeshAnimationAt()
std::map<std::string, math::Matrix4d> ActorMeshAnimationAt ( Entity  _id,
) const
[in]_idEntity's unique id
[in]_timeTimepoint for the animation
Map from the skeleton node name to transforms
◆ ActorMeshById()
rendering::MeshPtr ActorMeshById ( Entity  _id) const
[in]_idActor entity's unique id
Pointer to requested entity's mesh
◆ AddSensor()
bool AddSensor ( Entity  _gazeboId,
const std::string &  _sensorName,
Entity  _parentGazeboId = 0
[in]_gazeboIdEntity in Gazebo
[in]_sensorNameName of sensor node in Ignition Rendering.
[in]_parentGazeboIdParent Id on Gazebo.
True if sensor is successfully handled
◆ CreateActor()
rendering::VisualPtr CreateActor ( Entity  _id,
const sdf::Actor &  _actor,
Entity  _parentId = 0
Create an actor.
[in]_idUnique actor id
[in]_actorActor sdf dom
[in]_parentIdParent id
Actor object created from the sdf dom
◆ CreateCollision()
rendering::VisualPtr CreateCollision ( Entity  _id,
const sdf::Collision &  _collision,
[in]_idUnique visual id
[in]_collisionCollision sdf dom
Visual (collision) object created from the sdf dom
◆ CreateLight()
rendering::LightPtr CreateLight ( Entity  _id,
const sdf::Light &  _light,
Entity  _parentId
Create a light.
[in]_idUnique light id
[in]_lightLight sdf dom
Light object created from the sdf dom
◆ CreateLink()
rendering::VisualPtr CreateLink ( Entity  _id,
const sdf::Link &  _link,
Create a link.
[in]_idUnique link id
[in]_linkLink sdf dom
Link visual created from the sdf dom
◆ CreateModel()
rendering::VisualPtr CreateModel ( Entity  _id,
const sdf::Model &  _model,
Create a model.
[in]_idUnique model id
[in]_modelModel sdf dom
Model visual created from the sdf dom
◆ CreateVisual()
rendering::VisualPtr CreateVisual ( Entity  _id,
const sdf::Visual &  _visual,
Create a visual.
[in]_visualVisual sdf dom
Visual object created from the sdf dom
◆ EntityFromNode()
Entity EntityFromNode ( const rendering::NodePtr &  _node) const
[in]_nodeNode to get the entity for.
The entity for that node, or kNullEntity for no entity.
Todo:
(anyone) Deprecate in favour of gz::rendering::Node::UserData once that's available.
◆ HasEntity()
bool HasEntity ( Entity  _id) const
[in]_idUnique entity id
true if exists, false otherwise
◆ NodeById()
rendering::NodePtr NodeById ( Entity  _id) const
Pointer to requested entity's node
◆ RemoveEntity()
void RemoveEntity ( Entity  _id)
◆ Scene()
rendering::ScenePtr Scene ( ) const
Get the scene.
Pointer to scene
◆ SetScene()
void SetScene ( rendering::ScenePtr  _scene)
[in]_sceneScene pointer.
◆ SetWorldId()
void SetWorldId ( Entity  _id)
Set the world's ID.
[in]_idWorld ID.
◆ TopLevelNode()
rendering::NodePtr TopLevelNode ( const rendering::NodePtr &  _node) const
[in]_nodeChild node
Top level node containining this node
◆ TopLevelVisual()
rendering::VisualPtr TopLevelVisual ( rendering::VisualPtr  _visual) const
[in]_visualChild visual
Top level visual containining this visual TODO(anyone) Make it const ref when merging forward
◆ VisualById()
rendering::VisualPtr VisualById ( Entity  _id)
Retrieve visual.
[in]_idUnique visual (entity) id
Pointer to requested visual
◆ WorldId()
Entity WorldId ( ) const
Get the world's ID.
World ID
