SdfEntityCreator Class Reference
Provides convenient functions to spawn entities and load their plugins from SDF elements, to remove them, and to change their hierarchy. More...
#include <SdfEntityCreator.hh>
 SdfEntityCreator (const SdfEntityCreator &_creator)
 Copy constructor. More...
 SdfEntityCreator (EntityComponentManager &_ecm, EventManager &_eventManager)
 SdfEntityCreator (SdfEntityCreator &&_creator) noexcept
 Move constructor. More...
 ~SdfEntityCreator ()
Entity CreateEntities (const sdf::Actor *_actor)
 Create all entities that exist in the sdf::Actor object and load their plugins. More...
Entity CreateEntities (const sdf::Collision *_collision)
 Create all entities that exist in the sdf::Collision object and load their plugins. More...
Entity CreateEntities (const sdf::Joint *_joint)
 Create all entities that exist in the sdf::Joint object and load their plugins. More...
Entity CreateEntities (const sdf::Light *_light)
 Create all entities that exist in the sdf::Light object and load their plugins. More...
Entity CreateEntities (const sdf::Link *_link)
 Create all entities that exist in the sdf::Link object and load their plugins. More...
Entity CreateEntities (const sdf::Model *_model)
 Create all entities that exist in the sdf::Model object and load their plugins. Also loads plugins of child sensors. More...
Entity CreateEntities (const sdf::Sensor *_sensor)
 Create all entities that exist in the sdf::Sensor object. Sensor plugins won't be directly loaded by this function. More...
Entity CreateEntities (const sdf::Visual *_visual)
 Create all entities that exist in the sdf::Visual object and load their plugins. More...
Entity CreateEntities (const sdf::World *_world)
 Create all entities that exist in the sdf::World object and load their plugins. More...
SdfEntityCreator & operator= (const SdfEntityCreator &_creator)
 Copy assignment operator. More...
SdfEntityCreator & operator= (SdfEntityCreator &&_creator) noexcept
 Move assignment operator. More...
void RequestRemoveEntity (const Entity _entity, bool _recursive=true)
 Request an entity deletion. This will insert the request into a queue. The queue is processed toward the end of a simulation update step. More...
void SetParent (Entity _child, Entity _parent)
 Set an entity's parent entity. This function takes care of updating the EntityComponentManager and necessary components. More...
ignition/gazebo/SdfEntityCreator.hh This class provides wrappers around entities and components which are more convenient and straight-forward to use than dealing with the EntityComponentManager directly.
◆ SdfEntityCreator() [1/3]
SdfEntityCreator ( EntityComponentManager &  _ecm,
EventManager &  _eventManager
[in]_ecmEntity component manager. This class keeps a pointer to it, but doesn't assume ownership.
[in]_eventManagerEvent manager. This class keeps a pointer to it, but doesn't assume ownership.
◆ SdfEntityCreator() [2/3]
SdfEntityCreator ( const SdfEntityCreator &  _creator)
Copy constructor.
[in]_creatorSdfEntityCreator to copy.
◆ SdfEntityCreator() [3/3]
SdfEntityCreator ( SdfEntityCreator &&  _creator)
noexcept
Move constructor.
[in]_creatorSdfEntityCreator to move.
◆ ~SdfEntityCreator()
◆ CreateEntities() [1/9]
Entity CreateEntities ( const sdf::Actor *  _actor)
[in]_actorSDF actor object.
Actor entity.
◆ CreateEntities() [2/9]
Entity CreateEntities ( const sdf::Collision *  _collision)
[in]_collisionSDF collision object.
Collision entity.
◆ CreateEntities() [3/9]
Entity CreateEntities ( const sdf::Joint *  _joint)
[in]_jointSDF joint object.
Joint entity.
◆ CreateEntities() [4/9]
Entity CreateEntities ( const sdf::Light *  _light)
[in]_lightSDF light object.
Light entity.
◆ CreateEntities() [5/9]
Entity CreateEntities ( const sdf::Link *  _link)
[in]_linkSDF link object.
Link entity.
◆ CreateEntities() [6/9]
Entity CreateEntities ( const sdf::Model *  _model)
[in]_modelSDF model object.
Model entity.
◆ CreateEntities() [7/9]
Entity CreateEntities ( const sdf::Sensor *  _sensor)
[in]_sensorSDF sensor object.
Sensor entity.
CreateEntities(const sdf::Model *)
◆ CreateEntities() [8/9]
Entity CreateEntities ( const sdf::Visual *  _visual)
[in]_visualSDF visual object.
Visual entity.
◆ CreateEntities() [9/9]
Entity CreateEntities ( const sdf::World *  _world)
[in]_worldSDF world object.
World entity.
◆ operator=() [1/2]
SdfEntityCreator& operator= ( const SdfEntityCreator &  _creator)
Reference to this.
◆ operator=() [2/2]
SdfEntityCreator& operator= ( SdfEntityCreator &&  _creator)
noexcept
[in]_creatorSdfEntityCreator component to move.
Reference to this.
◆ RequestRemoveEntity()
void RequestRemoveEntity ( const Entity  _entity,
bool  _recursive = true
[in]_entityEntity to be removed.
◆ SetParent()
void SetParent ( Entity  _child,
Entity  _parent
[in]_childEntity which should be parented.
[in]_parentEntity which should be _child's parent.
