ParticleEmitter2 Class Reference
This is deprecated, please use the ParticleEmitter system. A system for running and managing particle emitters. A particle emitter is defined using the <particle_emitter> SDF element. More...
#include <ParticleEmitter2.hh>
 ParticleEmitter2 ()
 Configure the system. More...
This system will create a transport subscriber for each <particle_emitter> using the child <topic> name. If a <topic> is not specified, the following topic naming scheme will be used: /model/{model_name}/link/{link_name}/particle_emitter/{emitter_name}/cmd
Todo:
(nkoenig) Plan for ParticleEmitter and ParticleEmitter2:
  1. Deprecate ParticleEmitter in Gazebo Fortress.
  2. Remove ParticleEmitter in Gazebo G.
  3. Copy ParticleEmitter2 to ParticleEmitter in Gazebo G.
  4. Deprecrate ParticleEmitter2 in Gazebo G.
  5. Remove ParticleEmitter2 in Gazebo H.
◆ ParticleEmitter2()
