EnvironmentVisualization Class Reference
A GUI plugin for a user to load an Environment component into the ECM on a live simulation. More...
#include <EnvironmentVisualization.hh>
 EnvironmentVisualization ()
 ~EnvironmentVisualization () override
Q_INVOKABLE void ResamplePointcloud ()
void Update (const UpdateInfo &, EntityComponentManager &_ecm) override
 Plugin ()
virtual ~Plugin ()
void PostParentChanges ()
Properties
unsigned int xSamples {10}
 Samples along x axis.
unsigned int ySamples {10}
 Samples along y axis.
unsigned int zSamples {10}
 Samples along z axis.
void DeleteLater ()
std::string configStr
std::string title
gz/sim/systems/EnvironmentVisualization.hh
◆ EnvironmentVisualization()
◆ ~EnvironmentVisualization()
~EnvironmentVisualization ( )
◆ LoadConfig()
Reimplemented from Plugin.
◆ ResamplePointcloud()
Q_INVOKABLE void ResamplePointcloud ( )
Reimplemented from GuiSystem.
Property Documentation
◆ xSamples
◆ ySamples
◆ zSamples
