GuiSystem Class Reference
Base class for a GUI System. More...
#include <GuiSystem.hh>
virtual void Update (const UpdateInfo &_info, EntityComponentManager &_ecm)
 Plugin ()
virtual ~Plugin ()
void PostParentChanges ()
void DeleteLater ()
virtual void LoadConfig (const tinyxml2::XMLElement *_pluginElem)
std::string configStr
std::string title
A System operates on Entities that have certain Components. A System will only operate on an Entity if it has all of the required Components.
GUI systems are different from Systems because they don't run in the same process as the physics. Instead, they run in a separate process that is stepped by updates coming through the network
virtual void Update ( const UpdateInfo &  _info,
inlinevirtual
Reimplemented in EntityTree, PlaybackScrubber, EnvironmentLoader, EnvironmentVisualization, VisualizeFrustum, VisualizeLidar, AlignTool, ApplyForceTorque, CopyPaste, MouseDrag, Plot3D, Plotting, GzSceneManager, VideoRecorder, VisualizationCapabilities, and VisualizeContacts.
