#include <Plot3D.hh>
Signals
void ColorChanged ()
 Notify that the color has changed.
void LockedChanged ()
void MaxPointsChanged ()
 Notify that the maximum points has changed.
void MinDistanceChanged ()
 Notify that the minimum distance has changed.
void OffsetChanged ()
 Notify that the offset has changed.
void TargetEntityChanged ()
void TargetNameChanged ()
 Notify that target name has changed.
 Plot3D ()
 ~Plot3D () override
Q_INVOKABLE QVector3D Color () const
 Get the color of the plot.
Q_INVOKABLE bool Locked () const
 Get whether the plugin is currently locked on a target.
Q_INVOKABLE int MaxPoints () const
 Get the maximum number of points.
Q_INVOKABLE double MinDistance () const
 Get the minimum distance between points.
Q_INVOKABLE QVector3D Offset () const
 Get the offset in the target's frame.
Q_INVOKABLE void SetColor (const QVector3D &_color)
 Set the color of the plot.
Q_INVOKABLE void SetLocked (bool _locked)
 Set whether the plugin is currently locked on a target.
Q_INVOKABLE void SetMaxPoints (int _maxPoints)
 Set the maximum number of points. If the plot has more than this number, older points start being removed.
Q_INVOKABLE void SetMinDistance (double _minDistance)
 Set the minimum distance between points. If the target moved less than this distance, the latest position won't be plotted.
Q_INVOKABLE void SetOffset (const QVector3D &_offset)
 Set the offset.
Q_INVOKABLE void SetTargetEntity (Entity _entity)
 Set the target currently controlled.
Q_INVOKABLE void SetTargetName (const QString &_name)
 Set the name of target currently controlled.
Q_INVOKABLE Entity TargetEntity () const
 Get the target currently controlled.
Q_INVOKABLE QString TargetName () const
 Get the name of target currently controlled.
 Plugin ()
virtual ~Plugin ()
void PostParentChanges ()
void DeleteLater ()
Properties
QVector3D color
 Plot line color.
bool locked
 Whether the plugin is locked on an entity.
int maxPoints
 Maximum number of total points on the plot.
double minDistance
 Minimum distance between plot points.
QVector3D offset
 XYZ offset to the entity's origin to plot.
Entity targetEntity
 Target entity.
QString targetName
 Target entity scoped name.
std::string configStr
std::string title
This plugin can be instantiated multiple times to plot various entities.
The plugin is automatically attached to the currently selected entity, unless it is locked on an entity.
Configuration
  • <entity_name> (optional): Plot the given entity at startup. Accepts names scoped with ::, for example my_model::my_link. If not provided, the plugin starts not attached to any entity, and will attach to the next selected entity.
  • <color> (optional): RGB color of line, defaults to blue.
  • <offset> (optional): XYZ offset from the entity's origin to plot from, expressed in the entity's frame. Defaults to zero.
  • <minimum_distance> (optional): The minimum distance between points to plot. A new point will not be plotted until the entity has moved beyond this distance from the previous point. Defaults to 0.05 m.
  • <maximum_points> (optional): Maximum number of points on the plot. After this number is reached, the older points start being deleted. Defaults to 1000.
◆ Plot3D()
Plot3D ( )
◆ ~Plot3D()
~Plot3D ( )
◆ Color()
Q_INVOKABLE QVector3D Color ( ) const
The current color.
◆ ColorChanged
void ColorChanged ( )
signal
◆ eventFilter()
QEvent *  _event
overrideprotected
◆ LoadConfig()
Reimplemented from Plugin.
◆ Locked()
Q_INVOKABLE bool Locked ( ) const
True for locked
◆ LockedChanged
void LockedChanged ( )
signal
◆ MaxPoints()
Q_INVOKABLE int MaxPoints ( ) const
The current maximum points.
◆ MaxPointsChanged
void MaxPointsChanged ( )
signal
◆ MinDistance()
Q_INVOKABLE double MinDistance ( ) const
The current minimum distance.
◆ MinDistanceChanged
void MinDistanceChanged ( )
signal
◆ Offset()
Q_INVOKABLE QVector3D Offset ( ) const
The current offset.
◆ OffsetChanged
void OffsetChanged ( )
signal
◆ SetColor()
Q_INVOKABLE void SetColor ( const QVector3D &  _color)
[in]_colorNew color.
◆ SetLocked()
Q_INVOKABLE void SetLocked ( bool  _locked)
[in]_lockedTrue for locked.
◆ SetMaxPoints()
Q_INVOKABLE void SetMaxPoints ( int  _maxPoints)
[in]_maxPointsMaximum number of points.
◆ SetMinDistance()
Q_INVOKABLE void SetMinDistance ( double  _minDistance)
[in]_minDistanceNew distance.
◆ SetOffset()
Q_INVOKABLE void SetOffset ( const QVector3D &  _offset)
Set the offset.
[in]_offsetThe offset in the target's frame
◆ SetTargetEntity()
Q_INVOKABLE void SetTargetEntity ( Entity  _entity)
[in]_entityTarget entity ID.
◆ SetTargetName()
Q_INVOKABLE void SetTargetName ( const QString &  _name)
[in]_nameTargetName, such as 'world' or 'target'.
◆ TargetEntity()
Q_INVOKABLE Entity TargetEntity ( ) const
Target entity ID.
◆ TargetEntityChanged
void TargetEntityChanged ( )
signal
◆ TargetName()
Q_INVOKABLE QString TargetName ( ) const
◆ TargetNameChanged
void TargetNameChanged ( )
signal
Reimplemented from GuiSystem.
Property Documentation
◆ color
QVector3D color
readwrite
Plot line color.
◆ locked
bool locked
readwrite
◆ maxPoints
int maxPoints
readwrite
◆ minDistance
double minDistance
readwrite
◆ offset
QVector3D offset
readwrite
◆ targetEntity
Entity targetEntity
readwrite
Target entity.
◆ targetName
QString targetName
readwrite
