gz::sim::gui Namespace Reference
namespace  events
class  Plot3D
class  SelectEntities
 This plugin is in charge of selecting and deselecting the entities from the 3D scene and emit the corresponding events. More...
Functions
GZ_SIM_GUI_VISIBLE std::unique_ptr< gz::gui::Application > createGui (int &_argc, char **_argv, const char *_guiConfig, const char *_defaultGuiConfig, bool _loadPluginsFromSdf, const char *_sdfFile, int _waitGui, const char *_renderEngine=nullptr, const char *_renderEngineGuiApiBackend=nullptr)
 Create a Gazebo GUI application.
GZ_SIM_GUI_VISIBLE std::unique_ptr< gz::gui::Application > createGui (int &_argc, char **_argv, const char *_guiConfig, const char *_defaultGuiConfig=nullptr, bool _loadPluginsFromSdf=true, const char *_renderEngine=nullptr)
GZ_SIM_GUI_VISIBLE int runGui (int &_argc, char **_argv, const char *_guiConfig, const char *_renderEngine=nullptr)
 Run GUI application.
GZ_SIM_GUI_VISIBLE int runGui (int &_argc, char **_argv, const char *_guiConfig, const char *_sdfFile, int _waitGui, const char *_renderEngine=nullptr, const char *_renderEngineApiBackend=nullptr)
Function Documentation
◆ createGui() [1/2]
GZ_SIM_GUI_VISIBLE std::unique_ptr< gz::gui::Application > createGui ( int &  _argc,
char **  _argv,
const char *  _guiConfig,
const char *  _defaultGuiConfig,
const char *  _sdfFile,
int  _waitGui,
const char *  _renderEngine = nullptr,
const char *  _renderEngineGuiApiBackend = nullptr
[in]_argcNumber of command line arguments (Used when running without gz-tools. Set to 1 if using gz-tools). Note: The object referenced by this variable must continue to exist for the lifetime of the application.
[in]_argvCommand line arguments (Used when running without gz-tools. Set to the name of the application if using gz-tools)
[in]_guiConfigThe GUI configuration file. If nullptr, the default configuration from GZ_HOMEDIR/.gz/sim/gui.config will be used.
[in]_defaultGuiConfigThe default GUI configuration file. If no plugins were added from a world file or from _guiConfig, this configuration file will be loaded. If this argument is a nullptr or if the file does not exist, the default configuration from GZ_HOMEDIR/.gz/sim/gui.config will be used.
[in]_loadPluginsFromSdfIf true, plugins specified in the world SDFormat file will get loaded.
[in]_sdfFileSDF world file, or nullptr if not set.
[in]_waitGuiTrue if the server is waiting for the GUI to decide on a starting world.
[in]_renderEngine–render-engine-gui option
[in]_renderEngineGuiApiBackend–render-engine-gui-api-backend option
Newly created application.
◆ createGui() [2/2]
char **  _argv,
const char *  _defaultGuiConfig = nullptr,
bool  _loadPluginsFromSdf = true,
◆ runGui() [1/2]
GZ_SIM_GUI_VISIBLE int runGui ( int &  _argc,
char **  _argv,
-1 on failure, 0 on success
◆ runGui() [2/2]
char **  _argv,
int  _waitGui,
const char *  _renderEngineApiBackend = nullptr
[in]_sdfFileThe world file path passed as a command line argument. If set, QuickStart Dialog will not be shown.
[in]_waitGuiFlag indicating whether the server waits until it receives a world path from GUI.
