VisualizeLidar Class Reference
Visualize the LaserScan message returned by the sensors. Use the checkbox to turn visualization of non-hitting rays on or off and the textfield to select the message to be visualized. The combobox is used to select the type of visual for the sensor data. More...
#include <VisualizeLidar.hh>
Signals
void MaxRangeChanged ()
 Notify that maximum range has changed.
void MinRangeChanged ()
 Notify that minimum range has changed.
void TopicListChanged ()
 Notify that topic list has changed.
 VisualizeLidar ()
 ~VisualizeLidar () override
Q_INVOKABLE void DisplayVisual (bool _value)
 Set whether to display the lidar visual.
void LoadLidar ()
 Load the scene and attach LidarVisual to the scene.
Q_INVOKABLE QString MaxRange () const
 Get the maximum range of the lidar sensor (in metres).
Q_INVOKABLE QString MinRange () const
 Get the minimum range of the lidar sensor (in metres).
Q_INVOKABLE void OnRefresh ()
 Callback when refresh button is pressed.
void OnScan (const msgs::LaserScan &_msg)
 Callback function to get data from the message.
Q_INVOKABLE void OnTopic (const QString &_topicName)
 Set topic to subscribe for LidarSensor data.
Q_INVOKABLE void SetTopicList (const QStringList &_topicList)
 Set the topic list from a string, for example 'gz.msgs.StringMsg'.
Q_INVOKABLE QStringList TopicList () const
 Get the topic list as a string.
void Update (const UpdateInfo &, EntityComponentManager &_ecm) override
Q_INVOKABLE void UpdateNonHitting (bool _value)
 Set whether to display non-hitting rays.
Q_INVOKABLE void UpdateSize (int _size)
 Set lidar visualization size.
Q_INVOKABLE void UpdateType (int _type)
 Set visual type of LidarVisual.
 Plugin ()
virtual ~Plugin ()
void PostParentChanges ()
Properties
QString maxRange
 Max Range.
QString minRange
 Min Range.
QStringList topicList
 Topic list.
void DeleteLater ()
std::string configStr
std::string title
◆ VisualizeLidar()
◆ ~VisualizeLidar()
~VisualizeLidar ( )
◆ DisplayVisual()
Q_INVOKABLE void DisplayVisual ( bool  _value)
[in]_valueBoolean value for displaying the visual
◆ eventFilter()
QEvent *  _event
◆ LoadConfig()
Reimplemented from Plugin.
◆ LoadLidar()
void LoadLidar ( )
◆ MaxRange()
Q_INVOKABLE QString MaxRange ( ) const
Range, the maximum distance sensed by the sensor.
◆ MaxRangeChanged
void MaxRangeChanged ( )
signal
◆ MinRange()
Q_INVOKABLE QString MinRange ( ) const
Range, the minimum distance sensed by the sensor.
◆ MinRangeChanged
void MinRangeChanged ( )
signal
◆ OnRefresh()
Q_INVOKABLE void OnRefresh ( )
◆ OnScan()
void OnScan ( const msgs::LaserScan &  _msg)
[in]
LidarSensor message
◆ OnTopic()
Q_INVOKABLE void OnTopic ( const QString &  _topicName)
[in]_topicNameName of selected topic
◆ SetTopicList()
Q_INVOKABLE void SetTopicList ( const QStringList &  _topicList)
[in]_topicListMessage type
◆ TopicList()
Q_INVOKABLE QStringList TopicList ( ) const
Message type
◆ TopicListChanged
void TopicListChanged ( )
signal
Reimplemented from GuiSystem.
◆ UpdateNonHitting()
Q_INVOKABLE void UpdateNonHitting ( bool  _value)
[in]_valueBoolean value for displaying non hitting rays
◆ UpdateSize()
Q_INVOKABLE void UpdateSize ( int  _size)
[in]_sizeSize of lidar visualization
◆ UpdateType()
Q_INVOKABLE void UpdateType ( int  _type)
[in]_typeIndex of selected visual type
Property Documentation
◆ maxRange
QString maxRange
read
Max Range.
◆ minRange
QString minRange
read
Min Range.
◆ topicList
readwrite
Topic list.
