Translate and rotate links by dragging them with the mouse. Automatically loads the ApplyLinkWrench system. More...
#include <MouseDrag.hh>
Public Slots
void OnSwitchCOM (const bool _checked)
 Callback when COM switch is pressed.
Signals
void PosStiffnessChanged ()
 Notify that the translational stiffness changed.
void RotStiffnessChanged ()
 Notify that the rotational stiffness changed.
 MouseDrag ()
 ~MouseDrag () override
Q_INVOKABLE double PosStiffness () const
 Get the translational stiffness.
Q_INVOKABLE double RotStiffness () const
 Get the rotational stiffness.
Q_INVOKABLE void SetPosStiffness (double _posStiffness)
 Set the translational stiffness.
Q_INVOKABLE void SetRotStiffness (double _rotStiffness)
 Set the rotational stiffness.
 Plugin ()
virtual ~Plugin ()
void PostParentChanges ()
void DeleteLater ()
Properties
double posStiffness
 Stiffness of translation mode.
double rotStiffness
 Stiffness of rotation mode.
std::string configStr
std::string title
Configuration
  • <rotation_stiffness> : Stiffness of rotation mode, defaults to 100
  • <position_stiffness> : Stiffness of translation mode, defaults to 100
◆ MouseDrag()
MouseDrag ( )
◆ ~MouseDrag()
~MouseDrag ( )
◆ eventFilter()
QEvent *  _event
overrideprotected
◆ LoadConfig()
Reimplemented from Plugin.
◆ OnSwitchCOM
void OnSwitchCOM ( const bool  _checked)
slot
[in]_checkedTrue if force should be applied to center of mass
◆ PosStiffness()
Q_INVOKABLE double PosStiffness ( ) const
The translational stiffness
◆ PosStiffnessChanged
void PosStiffnessChanged ( )
signal
◆ RotStiffness()
Q_INVOKABLE double RotStiffness ( ) const
The rotational stiffness
◆ RotStiffnessChanged
void RotStiffnessChanged ( )
signal
◆ SetPosStiffness()
Q_INVOKABLE void SetPosStiffness ( double  _posStiffness)
[in]_posStiffnessThe new translational stiffness
◆ SetRotStiffness()
Q_INVOKABLE void SetRotStiffness ( double  _rotStiffness)
[in]_rotStiffnessThe new rotational stiffness
Reimplemented from GuiSystem.
Property Documentation
◆ posStiffness
double posStiffness
readwrite
◆ rotStiffness
double rotStiffness
readwrite
