Ogre2PointLight Class Reference
Ogre 2.x implementation of the point light class. More...
#include <Ogre2Light.hh>
virtual | ~Ogre2PointLight () |
Destructor. More... | |
virtual | ~BasePointLight () |
virtual | ~PointLight () |
Deconstructor. More... | |
virtual | ~Light () |
virtual | ~Node () |
virtual unsigned int | ChildCount () const =0 |
Get number of child nodes. More... | |
virtual math::Pose3d | LocalPose () const =0 |
Get the local pose. More... | |
virtual math::Vector3d | LocalPosition () const =0 |
Get the local position. More... | |
virtual math::Quaterniond | LocalRotation () const =0 |
Get the local rotation. More... | |
virtual math::Vector3d | Origin () const =0 |
Get position of origin. More... | |
virtual math::Pose3d | WorldPose () const =0 |
Get the world pose. More... | |
virtual math::Vector3d | WorldPosition () const =0 |
Get the world position. More... | |
virtual math::Quaterniond | WorldRotation () const =0 |
Get the world rotation. More... | |
virtual math::Vector3d | WorldScale () const =0 |
Get the world scale. More... | |
virtual | ~Object () |
virtual | ~Ogre2Light () |
virtual double | AttenuationConstant () const override |
Get the attenuation constant value. More... | |
virtual double | AttenuationLinear () const override |
Get the attenuation linear value. More... | |
virtual double | AttenuationQuadratic () const override |
Get the attenuation quadratic value. More... | |
virtual double | AttenuationRange () const override |
Get the attenuation range. More... | |
virtual bool | CastShadows () const override |
Determine if this light cast shadows. More... | |
virtual void | Destroy () override |
Destroy the light. More... | |
virtual math::Color | DiffuseColor () const override |
Get the diffuse color. More... | |
virtual Ogre::Light * | Light () const |
Get a pointer to ogre light. More... | |
virtual void | SetAttenuationConstant (double _value) override |
Set the attenuation constant value. More... | |
virtual void | SetAttenuationLinear (double _value) override |
Set the attenuation linear value. More... | |
virtual void | SetAttenuationQuadratic (double _value) override |
Set the attenuation quadratic value. More... | |
virtual void | SetAttenuationRange (double _range) override |
Set the attenuation range. More... | |
virtual void | SetCastShadows (bool _castShadows) override |
Specify if this light should cast shadows. More... | |
virtual void | SetDiffuseColor (const math::Color &_color) override |
Set the diffuse color. More... | |
virtual void | SetSpecularColor (const math::Color &_color) override |
Set the specular color. More... | |
virtual math::Color | SpecularColor () const override |
Get the specular color. More... | |
virtual | ~BaseLight () |
virtual void | SetDiffuseColor (double _r, double _g, double _b, double _a=1.0) |
virtual void | SetSpecularColor (double _r, double _g, double _b, double _a=1.0) |
virtual | ~Ogre2Node () |
virtual bool | HasParent () const override |
Determine if this Node is attached to another Node. More... | |
virtual bool | InheritScale () const override |
Determine if this visual inherits scale from this parent. More... | |
virtual math::Vector3d | LocalScale () const override |
Get the local scale. More... | |
virtual Ogre::SceneNode * | Node () const |
Get a pointer to the underlying scene node. More... | |
virtual NodePtr | Parent () const override |
Get the parent Node. More... | |
virtual void | SetInheritScale (bool _inherit) override |
Specify if this visual inherits scale from its parent. More... | |
virtual | ~BaseNode () |
virtual void | AddChild (NodePtr _child) override |
Add the given node to this node. If the given node is already a child, no work will be done. More... | |
virtual NodePtr | ChildById (unsigned int _id) const override |
Get node with given ID. If no child exists with given ID, NULL will be returned. More... | |
virtual NodePtr | ChildByIndex (unsigned int _index) const override |
Get node at given index. If no child exists at given index, NULL will be returned. More... | |
virtual NodePtr | ChildByName (const std::string &_name) const override |
Get node with given name. If no child exists with given name, NULL will be returned. More... | |
virtual unsigned int | ChildCount () const override |
virtual bool | HasChild (ConstNodePtr _child) const override |
Determine if given node is an attached child. More... | |
virtual bool | HasChildId (unsigned int _id) const override |
Determine if node with given ID is an attached child. More... | |
virtual bool | HasChildName (const std::string &_name) const override |
Determine if node with given name is an attached child. More... | |
virtual bool | InheritScale () const override=0 |
virtual math::Pose3d | LocalPose () const override |
virtual math::Vector3d | LocalPosition () const override |
virtual math::Quaterniond | LocalRotation () const override |
virtual math::Vector3d | LocalScale () const override=0 |
virtual math::Vector3d | Origin () const override |
virtual NodePtr | Parent () const override=0 |
virtual void | PreRender () override |
virtual NodePtr | RemoveChild (NodePtr _child) override |
Remove (detach) the given node from this node. If the given node is not a child of this node, no work will be done. More... | |
virtual NodePtr | RemoveChildById (unsigned int _id) override |
Remove (detach) the node with the given ID from this node. If the specified node is not a child of this node, no work will be done. More... | |
virtual NodePtr | RemoveChildByIndex (unsigned int _index) override |
Remove (detach) the node at the given index from this node. If the specified node is not a child of this node, no work will be done. More... | |
virtual NodePtr | RemoveChildByName (const std::string &_name) override |
Remove (detach) the node with the given name from this node. If the specified node is not a child of this node, no work will be done. More... | |
virtual void | RemoveChildren () override |
Remove all child nodes from this node This detaches all the child nodes but does not destroy them. More... | |
virtual void | RemoveParent () override |
Detach this Node from its parent. If this Node does not have a parent, no work will be done. More... | |
virtual void | Scale (const math::Vector3d &_scale) override |
Scale the current scale by the given scalars. More... | |
virtual void | Scale (double _scale) override |
Scale the current scale by the given scalar. The given scalar will be assigned to the x, y, and z coordinates. More... | |
virtual void | Scale (double _x, double _y, double _z) override |
virtual void | SetLocalPose (const math::Pose3d &_pose) override |
Set the local pose. More... | |
virtual void | SetLocalPosition (const math::Vector3d &_position) override |
Set the local position. More... | |
virtual void | SetLocalPosition (double _x, double _y, double _z) override |
virtual void | SetLocalRotation (const math::Quaterniond &_rotation) override |
Set the local rotation. More... | |
virtual void | SetLocalRotation (double _r, double _p, double _y) override |
virtual void | SetLocalRotation (double _w, double _x, double _y, double _z) override |
virtual void | SetLocalScale (const math::Vector3d &_scale) override |
Set the local scale. More... | |
virtual void | SetLocalScale (double _scale) override |
Set the local scale. The given scale will be assigned to the x, y, and z coordinates. More... | |
virtual void | SetLocalScale (double _x, double _y, double _z) override |
virtual void | SetOrigin (const math::Vector3d &_origin) override |
Set position of origin. The position should be relative to the original origin of the geometry. More... | |
virtual void | SetOrigin (double _x, double _y, double _z) override |
virtual void | SetWorldPose (const math::Pose3d &_pose) override |
Set the world pose. More... | |
virtual void | SetWorldPosition (const math::Vector3d &_position) override |
Set the world position. More... | |
virtual void | SetWorldPosition (double _x, double _y, double _z) override |
virtual void | SetWorldRotation (const math::Quaterniond &_rotation) override |
Set the world rotation. More... | |
virtual void | SetWorldRotation (double _r, double _p, double _y) override |
virtual void | SetWorldRotation (double _w, double _x, double _y, double _z) override |
virtual void | SetWorldScale (const math::Vector3d &_scale) override |
Set the world scale. More... | |
virtual void | SetWorldScale (double _scale) override |
Set the world scale. The given scale will be assigned to the x, y, and z coordinates. More... | |
virtual void | SetWorldScale (double _x, double _y, double _z) override |
virtual math::Pose3d | WorldPose () const override |
virtual math::Vector3d | WorldPosition () const override |
virtual math::Quaterniond | WorldRotation () const override |
virtual math::Vector3d | WorldScale () const override |
virtual math::Pose3d | WorldToLocal (const math::Pose3d &_pose) const override |
Convert given world pose to local pose. More... | |
virtual | ~Ogre2Object () |
virtual ScenePtr | Scene () const override |
virtual | ~BaseObject () |
virtual unsigned int | Id () const override |
virtual std::string | Name () const override |
virtual void | PostRender () override |
Ogre2PointLight () | |
Constructor. More... | |
BasePointLight () | |
Ogre2Light () | |
virtual void | Init () override |
Initialize the light. More... | |
BaseLight () | |
virtual void | Reset () |
Ogre2Node () | |
virtual bool | AttachChild (NodePtr _child) override |
virtual NodeStorePtr | Children () const override |
virtual bool | DetachChild (NodePtr _child) override |
virtual void | Load () override |
virtual math::Pose3d | RawLocalPose () const override |
virtual math::Vector3d | RawLocalPosition () const |
Get the raw local position of the node. More... | |
virtual math::Quaterniond | RawLocalRotation () const |
Get the raw local rotation of the node. More... | |
virtual void | SetLocalScaleImpl (const math::Vector3d &_scale) override |
Implementation of the SetLocalScale function. More... | |
virtual void | SetParent (Ogre2NodePtr _parent) |
Set the parent node. More... | |
virtual void | SetRawLocalPose (const math::Pose3d &_Pose3d) override |
virtual void | SetRawLocalPosition (const math::Vector3d &_position) |
Set the raw local position of the node. More... | |
virtual void | SetRawLocalRotation (const math::Quaterniond &_rotation) |
Set the raw local rotation of the node. More... | |
BaseNode () | |
virtual NodeStorePtr | Children () const=0 |
virtual void | PreRenderChildren () |
virtual math::Pose3d | RawLocalPose () const=0 |
Ogre2Object () | |
BaseObject () | |
double | attenConstant = 1.0 |
Attenuation constant value. More... | |
double | attenLinear = 0.0 |
Attenuation linear factor. More... | |
double | attenQuadratic = 0.0 |
Attenuation quadratic factor. More... | |
double | attenRange = 100.0 |
Attenuation range. More... | |
Ogre::Light * | ogreLight = nullptr |
Pointer to ogre light. More... | |
Ogre::Light::LightTypes | ogreLightType |
Light type. More... | |
Ogre2NodeStorePtr | children |
A list of child nodes. More... | |
Ogre::SceneNode * | ogreNode = nullptr |
The underlying ogre scene node. More... | |
Ogre2NodePtr | parent |
Pointer to the parent ogre node. More... | |
math::Vector3d | origin |
Ogre2ScenePtr | scene |
Pointer to the ogre scene. More... | |
unsigned int | id |
std::string | name |
◆ Ogre2PointLight()
protected |
◆ ~Ogre2PointLight()
virtual |
